I just received my Lemfo 12 Pro. I am wondering how to sync my contacts with Google. I installed Google Contacts from the Play Store, but, no matter how many times I try, the sync option will not stay on. Any thoughts or is there a 3rd-party app I should be using?
Hi. Thank you. Alternatively, you can copy contacts from your phone using BlueTooth. Of course, this will risk getting duplicates with multiple copies. Rajiv
Hi. Following up on this issue. Is the technical problem getting the requisite approval for the digital certificates used to authenticate with Google’s servers or something else entirely?
Hi. I am following up with a fix to this issue. I tried the steps below and was successfully able to sync my contacts. The instructions that I have written up below explain the process:
Overview:
The Android 10 watches do not come with the Google Contact Sync service automatically installed. It must be installed manually. As an extra measure, please also download the Google Contacts app from the Google Play Store. For the complete steps, see below:
(1) Download the Google Contact Sync app for Android 10 from APKMirror or for easier use, you can also use my Google Drive link https://drive.google.com/file/d/1rwo7qpudBcBEwd7lq29aWHDQ-u_JzFPH/view?usp=drivesdk (your choice).
(2) Install the app and then go to Settings\Apps and Notifications.
(3) Tap on show all apps installed on your device.
(5) Tap on Google Contact Sync, and give it permissions to read your contacts in the permissions area.
(6) Now download Google Contacts from the Play Store, https://play.google.com/store/apps/details?id=com.google.android.contacts&hl=en_US&gl=US
(7) After Google Contacts gets installed, tap on your Google account. This should now allow your contacts to sync automatically from your Google account.
To get rid of the duplicate contacts you mentioned in this thread, you can browse to contacts.google.com, There is an option there to merge duplicates.
The contact sync app will not install on my LEM15 either by clicking to install in the watch or using adb install. Here is the message given when using adb install:
Failure [INSTALL_FAILED_OLDER_SDK: Failed parse during installPackageLI: /data/app/vmdl1427358596.tmp/base.apk (at Binary XML file line #6): Requires development platform S but this is a release platform.]
I can install Contacts from the Play Store and enable contact sync in Google services. It says waiting to sync in the Contacts app
Perfect solution - I had not realised I was installing an apk for Android 9. This solution worked for me and all my contacts are now being synced. Much better that importing and trying to keep things synced manually.
Thanks!
Thank you for these directions …it worked flawlessly on my Optimus 2 … I sideloaded the Android 10+ sync app apk from my cloud storage and to my phone via cx file explorer with cloud access and as soon as it installed it synced my Contacts to everything… I the loaded the contacts app and the Google phone app and all contacts appeared instantly !! My new Optimus2 is now perfect and Sim card ready… I love this group/forum.
