If you’ve read about the problem with notification led, you’ve probably read the solution as well, so why not try that yourself instead of waiting for kospet to fix it? I case you’ve only read about the problem and not the solution, or if you’ve forgotten it, here is the app you can use to fix it: MTKnoLED.apk | by Kesarwani_17 for Juice 2 (AQ5001)
or you can do this:
I ve read about the problem and the solution too very analytically. But as you maybe remember there were comments reporting problems after the usage of MTKnoLED.apk.
So can you be a little more specific how can i use your second way ‘‘settings put system notification_light_pulse 0’’
I m coming back again and the reason is a lot of problems with my Kospet optimus pro 3/32.
Firstly i lost the activation - termination sounds.
Afterward they came back but ** i lost vibration.**
Additionally in google play store app, the home page doesn t open and there is always a selection button for loading. No matter how many times i push it it doen t open the page.
Whether all these problems are related with the ‘MTKnoLED.apk’ that i installed at about 20 days ago?
So let’s start with the basics.
Have you changed anything else ?
I would start by making a backup of anything you need on the storage and then factory reset.
There is a known issue with Google services at the moment. Fix is here: Important for all Android Watch owners - Google Error
