I love the X7.
If only they had listened about the bezel and the black ring around the screen and the battery size…
But Finow were very stubborn
The higher res screen of 450 x 450 is fantastic but needs more power.
I will let you know if I hear anything about better power saving.
I must admit that 1.5 is actually very good considering what you are dealing with.
would the charging cradle dock from the new Lemfo, the one with a 900mah rechargable power bank, be able to charge and work with the kospet optimus pro?
if not, is there any similar type of dock made specifically for the optimus ?
No - magnets are opposites - will not connect. They also reverse the pin order so watch out you don’t blow the power chip inside the watch.
I am going to try and get Kospet to release a dock with battery - it makes sense these days.
However - there will be a Kosptet Prime 2 soon.
I can’t say much else at the moment but it will not be long. Maybe June…
thanks for the heads up in regards to the reverse pin order pablo
was hoping to have a power bank dock compatible with the optimus as only had it less than a year and not looking to upgrade the watch just yet, if there would be a kospet compatible power bank cradle in the future, that would be a major win.
Maybe I bricked my Optimus
I first tried to patch TWRP to my optimus which failed because my storage was encrypted. I thought than it could be a good idea to select “Format all & Download”
Until then I got an “Preloader” Error in the SP Flash tool and after I removed the USB device driver and plugged the watch again in the driver was installed automatically but the watch is not rekognized by the SP Flash tool anymore.
I hope not everything is lost, because the scatter file only located the boot and recovery partition. So maybe not everything is formatted then?
Is there a way to bring my watch back to life?
I wanted to install the 2.5 firmware by using the “Upgrade Firmware” option, but it fails by not rekognizing the device anymore.
Normally it’s possible to load the firmware in the flash tool using firmware update option and click download. Then connect the watch (powered off).
If flash doesn’t start then press the power button a couple of times to see if flash starts.
Otherwise you have to let battery completely discharge of take the back off and disconnect the battery to release the preloader.
I strongly suggest that you don’t try to disconnect the battery - it’s so easy to damage the watch doing this!
If I choose “firmware update”, “download” and connect the watch the progress bar on the bottom gets red and I always get the “Preloader invalid” error.
I wonder how to let it completely discharge, because it will not boot in any way. When I hold the power button some time the green light of the sensor on the back flashes shortly but nothing else happens.
It depends.
What is your watch (including ram and storage size)
So you have an Optimus… Sorry.
But is yours 1 + 16 or 3 + 32 ram and storage?
Is it a Kospet model or KingWear or other brand?
Several brands released this model which is really called KC09.
Hi Pablo
In my previous question i was meaning if the firmware V3.0_20190830 is the last for kospet optimus pro or you are planning to give sometime in the future another update.
I m asking you again because optimus pro is a really good watch but with tragic battery life.
For example the battery life (from 100%) with sim enabled and making 5-6 calls, lasts about 14 hours.
Especially in case that i m turning on wifi and watch some videos on utube, then it only lasts at about 4-5 hours (from 100%).
Additionally if i just set up a clock alarm (no sim, no wifi, no bt, no gps), after the belling the battery duration lasts at about 5 hours and the only way to stop this battery drain is the reboot.
Generally after any notification (calendar, clock alarm etc) i have to reboot the watch to avoid the tragic battery drain.
