Let me guess after update factory reset?
yep, if you donât factory reset after going from 1.0 to 1.2 then you wonât be able to open the power menu
The new V1.0 packages has been updated, they include a factory reset and are based on V1.2.
It is basically just called V1.0 to indicate the upgrade capability from the original firmware.
Yes it is fine to update to any version after you have updated from stock to v1.0.
Factory reset should always be done with beta testing and thatâs why it is written in the original top post.
This is normal due to framework changes and menu changes that simply wouldnât work properly without a reset.
when we will get global stable version OTA update for optimus 2
There is no guarantee you will OTA . However the latest build is amazing . Why not give it a try ?
Yes thatâs right.
We have not implemented the âdownload watch faceâ facility and we will probably remove the icon.
Especially as some people (cough cough) complain about the available selection of faces not being to their liking.
This way it goes back to how it was before this function appeared.
People need to take the initiative and download faces that they actually want by visiting places where they are available.
That feature was aimed at the domestic market (China) where they can not visit the various locations to download content due to the Great Firewall.
This firmware is designed with choice in mind.
So people can decide for themselves what they want to download.
We will discuss it further, depending on feedback.
This is the whole point of a beta program.
It might never get to official OTA.
Even though this is us working directly with them to create a more âInternationalâ experience.
The reality is that it may not be acceptable to the brands.
If they decide that they cannot do without Wiiwear, watch face store / download and all the custom bloat apps - we can only keep it here.
Still worth it in our opinion, regardless.
By the way, while on the subject of watch faces @anon5802783
Have you tried this?
Its pretty awesome.
Universal Launcher crashes after I updated to FAW v1.3.
Did you factory reset before you install it?
If problem persists after a factory reset then it will be a permissions problem or something like that.
I did every time with each new firmware
Might be worth asking Eric about it in universal launcher support thread?
Edit:
You are aware that you can modify the font size?
A bit over dramatic, are we?
It is considered beta for a reason, those changes are subject to change and reported bugs are going to be fixed.
And as I linked on my previous post, you can just flash back to the default firmware.
I totaly agree.
The reason why the music player was removed, is because it was a prebuilt application that only used the launcher as âcontrol unitâ. It is currently the same situation with the fitness application.
This is something that i personally donât like (forced external dependencies), thatâs why the step counter and weather were remade as a launcher built-in.
The philosphy here is: either have it built into the launcher or only have a external app.
I might build a replacement for the music player as soon as all the current bugs on the launcher are ironed out.
Strava finds gps faster on faw1.3b1 than on 1.2, from what I experience
Today I tested the new versions (1.0, 1.2 PRIME2 battery level 50%). In both versions, the battery charge control malfunctions. If I connect the watch to a constant stable 5 volts, after about 10 minutes, the charging current will start to fluctuate. It ranges from 0.2 to 0.6A for about 0.5 minutes.
It then rises to 1.3-1.4A and the watch heats up a lot. At 1.4 firmware, 0.65A current consumption is stable up to 90% of the battery. It then decreases continuously. (As it should be) I reset to 1.4 and it works fine again. Thatâs why I think itâs a software bug. I also tried it with 3 different chargers and a lab power supply. (Each device works flawlessly)
