Hello again, thanks for helping each other. Play Store does not allow all devices to be updated at the same time and it may take a while to release the final version to all, so if you have update problems I leave the link of the 3 applications:
Watch Droid Phone 15.10.40.10
Watch Droid Assistant 15.10.40.10
Watch Droid Assistant - WearOs 15.10.40.10
It is very important to restart the smartwatch after updating for a correct start of the application and lower battery consumption.
In your case, it asks you to update the phone application, the smartwatch is the last one.
You have 2 options:
As you have been told you can uninstall and reinstall from Play Store, if you are a Premium user it will automatically be activated the first time you enter.
Download the apk that I posted in the previous answer.
I have developed all the new options in such a way that you can disable and configure the options that you do not want to have active.
Each one is independent and does not run in constant services, they only activate to take the necessary data and then become inactive again.
The Heart Rate option may be the one that wears the most battery, but it still has to be minimal. Everything is now logged in the battery and event log. For this reason, the consumption of each of the options can be determined with details in order to better control all the things that happen within the application.
Battery:
Battery consumption and event log
Graphics and consumption statistics
Events graphed according to selected range
Possibility of changing the color of each of the events
Control of percentage of charge, status, type, temperature, battery voltage.
Estimated total battery charge and discharge time
Smartwatch charging completion notice
Heart Rate:
Automatic measurement of the heart rate according to configuration
Continuous heart rate measurement for 5 min, 15 min, 30 min, 1 hour
Measurement graphs according to selected range
Statistics of maximum, minimum and average measurements
Step Tracking:
Track daily activity log counting steps taken
Graphs of number of steps daily, weekly and monthly
Daily goal mark and chart color according to activity
Estimation of distance, steps and daily average according to selected range
Display:
Improved configuration options
Color change for better viewing and less battery consumption
Blue star functions that can be activated even if you are not a Premium user
Many bugs fixed
Thank you all for your answers, I can finally download the 15.1 version on both my phone and my watch, I“m a premium user and so far it works like a charm, Thanks
I love the new app
Is there a way to add a, if charging do not check heart rate.? Would be nice for the genesis and LEm 12 owners so it doesnāt try checking heart rate when using the charging dock since it blocks the sensors
Is there a way to sync the heart rate and sleep data to Google fit or other fitness app?
Thank you very much for your report, I will take it into account for the next version, if the smartwatch is charging its battery, do not take the heart pulse
The possibility of initiating a call by quick contact was discontinued in v9.1 due to the new Play Store policies, unfortunately the sources of those versions are no longer there and I cannot modify them. Sorry I try to continue improving the application with the little time I have.
Hello maybe is a silly Questin but⦠I just paid for the premium version and i“m using it o my Kospet Prime, I also have a thor dual 4. the question is: can i use the premium version i have to pair both watches?? thanks in advance
I have a feature request if it is possible,I love your app itās working great with my kospet optimus, I would really like if you could add incoming calls action buttons like Google dialer for the miui dialer and also can you please make separate widgets for notifications and music panel ,I use your widget panel and it will be great to swipe down to see notifications directly instead of app like layout.
With the new version everything works correctly but I only have a problem with the heart rate detection.
The long time measurement (5, 15, 30 minutes) works great. If, on the other hand, I make a manual instantaneous measurement or an instantaneous programmed in time ⦠this measurement is wrong and always the same. I noticed that in these instant measurements the green light of the sensor on the bottom of the smartwatch turns on for an instant and then turns off, probably the error depends on this.
