And arguably a better screen “usable area” ratio than the LEM T.
Depending on who you talk to, of course
By the way doesn’t let me install Facebook says not compatible with android device
Can’t use instagram horizontally any1 know how to fix it?
@Dr_Andy_Vishnu published this a few month ago:
-Ticwris MAX S and KOSPET Note firmware thread-UPDATED - #13 by Dr_Andy_Vishnu
It is an app that allows you to choose a suitable screen orientation for each app you use.
Tried didn’t work
Have you read the post I’ve linked? It’s important to chose the right settings…
I can clarify along with @Dotsfar who found this app . It does wotk
Instagram works vertically
Changed setting as in picture described but instagram works vertically only
Damn forgot about that soz bro
It worked
turned of optimization hope it wont drain battery a lot
You are welcome…
When you turn off optimization it drains a lot battery
Why not check it out instead off asking questions? Just wondering…
It doesn’t need much battery, if I remember right.
Sorry mistaken post
A post was merged into an existing topic: Advice on Kospet Note
Sorry if I make you angry with this question but I need to ask
I just ordered Lokmat Max
Just wanted to know FAW firmware can be installed on this model?
This question baffles me. I don’t intend to answer that. Do you read anything at all here in this forum? Or are you just looking for people who will feed you with the right answers to your questions???
@Armen_Tangyan
I imagine that you already have an answer about optimization by now:)) about A10 for this watch check out the thread about the firmware thread, i domt have this watch but most likely youll get answer there for what you need:))
@sonia_sophie_ataunna the watch comes with Android 10 as stock.
