Max S FAW Android 10 Firmware Impression
When i open the file on the watch its saying do you want to install an update to this built in fitness app,so i select continue…then it says install ,so i select yes.then it comes up app not installed…and the existing fitness app hasnt changed and is the same when i checked it…it doesnt count steps,kmh,etc etc
Sounds like it is not going to be possible to use it then.
Sorry about that but as I said, we were not interested in fitness monitoring.
There is only a motion sensor and so step monitoring was never going to be accurate.
Basically, just lifting your arm counts as a step because it is a motion.
With this in mind we didn’t want to waste our time.
We were focused on the watch function, stability and usability.
Especially around properly integrating the Google eco system.
Having said that, have you checked the required permissions for the fitness app?
It would need access to the sensors, for example. Plus many more permissions.
If I have time, I will have a look.
If it does not work out for you, go back to the stock firmware.
If you want this particular functionality.
so based on what you just said google fit should work then?i will download it and try tomorrow
You can try it but whether or not it can access sensor output, I don’t know.
Most people are using the my running app which has its own section here on the forum and apparently can be linked to Google Fit.
Check it out here
More here from recent posts about this
Older but still relevant
The search function here is extremely good :+1:
@Logan1 - I realize this was a long time ago, but curious how things turned out with My Running app and Google Fit?
The development of MRA stopped which is a shame as its great and yes it syncs to googlefit
Much thanks @Dr_Andy_Vishnu. Helpful info.
Sadly this app will eventually grind to a halt as watches progress. I have noticed already on some newer watches the option of using the watches heart rate monitor within the app doesnt always work
Hello everyone, just a simple question because I am new to the swartwatch world: with android 10 will be bluetooth call possible? I would like to answer my smartphone with my smartwatch like I did with the galaxy watch without the need of a second sim card. I saw that there are only 3 smartwatches with this form factor, and if android 10 allows me to use it like it has bluetooth call functions, I will buy the tiwris. (I loved the Lokmat appllp for the specs and the detatching-button-thing, but I read that software side is the worst smatwatch ever).
First of all: The Galaxy Watch is not a full Android watch and is not supported here. Bluetooth calling only worked up to Android 5.
However, if I understood you correctly, would you like to see who is currently calling you on the watch so that you can then use your smartphone to make a call? This is possible if the SIM card is in the smartphone and the watch and the smartphone are connected to each other via Bluetooth. The app required for this is called Watchdroid. As well as a special dialer on your smartphone.
However, this solution does not work for iPhones.
I know, the galaxy had Tizen (reason why I hated it). I don’t need to talk with the smartwatch microphone and speaker, I’m satisfied to just have a “pop up” for incoming calls where I can answer and the possibility to dial telephone numbers on the watch and call on the smartphone, audio can be on buds too, I don’t mind it.
Sorry for my bad English and thanks for your time.
Btw I live in Germany, we have no Google voice yet and a clone of my SIM card will cost 10€ per month, but I have unlimited data on my smartphone and I can have hotspot always on.
These Smart Watch are made to work with a sim card inside and forget your phone. i live in France and use a Max S since 3 years, no more phone… :grinning:
Bluetooth call - no
Hello, I was reaching to request Trust Level 2 as I believe I have met the requirements. I know it is a holiday week and know it may take awhile respond. But did want to reach out thank you again.
You are level 2 member now.
I reviewed your issue and I suspect that it is due to the long time between visits.
It’s fixed now :+1:
Thank you sir and enjoy the holiday!
This is gonna be my nee goal! :slight_smile:
When reading different topics and posts, I cant seems to understand, why this firmware only seems to works on the MAX s or the DM101 (if im not mistaking) The hardware is almost identical.
When upgrading the DM101, is this possible on the 1 GB variant of this Watch or is the 3 GB version needed?
thanks for this information
