No need for that.
It’s all good but I think your statement might be modified to say that “so far you have not succeeded in rooting the device”
Rather than the “it is not possible” type statement.
I just got my TICWRIS MAX a few days ago, and what you’ve described is EXACTLY what I want to do! I’ve had the Electric Matrix Live Wallpaper on my Android phones for years. It’s definitely the best live wallpaper available for Android, and it would be perfect on the TICWRIS MAX, but like you, I can’t seem to figure out how to install it on the watch. Does anyone have any suggestions?
You say that it’s possible to use animated gifs when using the Future Launcher on the TICWRIS MAX. I also have the Future Launcher and the Sci-Fi Launcher on my One Plus 6T Android phone and would like to use that launcher on the Max if it means that I’ll be able to utilize the Electric Matrix Live Wallpaper on the smartwatch. How do you activate animated gifs within Future Launcher? I’ve done everything I can think of to activate the function with no success. Any suggestions?
Lost the ability to transfer files back and forth to my Win 10 pc. is there a driver file i need to reinstall on the PC?
Try going to the device manager and select the MTP driver.
You have enabled file transfer for USB on the watch?
Found a Mediatek driver i did not recognize on PC. Uninstalled it and USB transfer is back.
Just tried to flash TWRP.
Already downloaded every file needed.
Already tried SP Flash tool, and no way to boot on TWRP.
Just tried with Flashtool… and this is the result…
Why is in locked state?
I just already activate USB debug, and OEM bootloader allowed.
I’m really confussing…
trying whit “fastboot oem unlock” at screen you can see the option to unlock, but you need to press (Volume UP)… How I can press it? Buttons are not responding so I figure thet they are not volume buttons…
Please, may you help me…???
Thanks in advance
Just another try…
After probing to push down both buttons at same time, looks like answer as OKAY (Just unlcked???)
but no way
I jus tried again to fastboot flash recovery recovery.img and still look like not unlocked
Please, I’m really feeling stupid man…
How, you all get it???
Again thanks in advance for your help
thanks a lot, i’m having issue with lines across the screen and i use a upgrade option with this firmware, it works now but how do i root it please
Read through the LEM T FAQ thread as all the details are there.
You will have to patch your boot image with magisk.
Easy enough to do on a mobile phone.
I have concerns about the twrp working on the different screen type.
So, until this is properly tested I suggest you patch the boot image, install magisk manager on your watch and flash the patched boot image using the flash tool.
The scatter file and the boot image should be fine and flash using download only.
Once you have booted and turned on Wi-Fi, magisk should be able to run the update and install the zip file.
Hopefully that will be all you need to do.
If you have problems it could be that a 32 bit version of Android is needed to patch the boot image.
See how it goes. At least you have the stock firmware now…
You can check this TWRP if you want…
YEs, please,
I just already got it !!!
Thanks to @noidremained, for their TWRP image for “D” firmaware variante, finally I just be able to boot into TWRP
Thanks a lot for your help
Let’s try my version then
- Insert into internal memory boot.img and magisk zip
- Flash both boot and recovery using twrp.img using flashtool
- Turn on your watch, then install img>choose boot. Img.
- Install zip>choose magisk zip
- Reboot system
This way is more useful if you doesn’t have patched boot.img since boot into system normally will overwrite twrp with stock recovery.
This is great news.
Thank you @Julián_Chico
This is good news for the people who have type D screens
My LEM T Arrived today, the D variant.
Build quality is good, but unfortunately my IMEI got blocked. it seems ever imei started with 86XXXXXX got blocked here, the one started with 35XXXXXX not. even when both not registered in my country database.
I hope in the future all FAW IMEI will start with 35XXXXX to avoid blocking
EDIT: I don’t believe the first thing I do when receiving mine was to change IMEI lol, but luckily everything available online. but I won’t point anything here though since it’s illegal
Mine starts with 3xxxx
Excellent, I was just about to message you and you have already done it ![]()
thanks for that, but this isn’t my first rodeo lol.
What is your location out of interest?
I know India and Turkey have issues with the imei
