no android lite mode
is there android lite mode available on FAW 1.3 for optimus2
yes i am missing android lite mode that saved my battery a lotš
@Rohit_Bhandari No - it didnāt really.
It is just hiding apps in the menu.
You can just use power saver instead of using a fake āmaskingā system.
Guys can u fix sensor issue plssssssssssssss
In 1.3 I want to slide down to turn on wifi but sometimes when I try slide down watch doesnāt understand this is reallly annoying.
Plus step count shows with minus sign
Actually did but for safety did 2nd time.Currently I have issue with notifications.When notifications comes out I try slide it to see but shows 0 notification s
hello, i went to 1.3b3. didnāt like it. not a daily driver. so i went down to faw 1.4 , worked good then went to version faw 1.0 installed fine, tried locale update to go to faw 1.2, no go. got the dying android robot. tried to download the legacy 1.0 but says itās not there. what do i do
Flash stock and then update to 1.0
The FAW version is designed to not allow downgrade apart from flashing back to stock.
Where can I find the stock rom? And is the version 1 the legacy rom, if so the links do not work.
the stock rom is 1.4 and youāll find the newest version of 1.0 in the top post of the following thread: International Firmware Beta [V1.3] (Optimus2, Prime2, LEM12Pro, LEM14, LEM15)
thanks, BUT version 1 that you referred to is a zip file and version 1.4 does not have local update
Thatās correct.
Stock firmware requires flash tools and the international firmware is for updating from the watch storage using the built in OTA software.
okay, when i put the version faw 1 in watch storage the file is a zip and there are question marks on all the other files in the zip, then it says file is unknown format
I hope you read up on how to use the update zip? This is for the S10 LEM 14 but it is the same as all the other watches.
Make sure you only download the FAW firmware from this post. V1.0 is attached to it
When I ordered my watch version was 1.5
Does not matter.
If you flash 1.4 you can take the OTA if it is available.
Or just update to International v1.0.
Either way, flashing v1.4 stock is fine
Just remember that you need flash tools to install stock firmware.
After flash just tried OTA update no update available.
But in the end end up with FAW 1.0 cause tap to wake function is really nice I am trying to avoid buttons use to make their life longer
Yep, fair enough
