But I’ll need to flash to faw 1.0 before beta local update right?
Right now I flashed to original 1.4 do I need to flash for FAW 1.0 or just local update it?
Cause when I want to load scatter.txt flash tools says it’s invalid file
local update, a zip that works for local update does not work with sp flash tools and vice versa
Another question than instal FAW 1.0 than latest beta?
I believe so, unless something has changed
Thnx for respond
I am flashing back to FAW 1.0 beta 3 works veryyyyyyyyy bad on my watch
By the way conection between pc and watch in beta 3 are uter hard
For Faw 1.0 I need to flash???
Just 2 things I want to know. 1:This beta 3 includes beta 2 updates?
2: When I try to watch instagram user’s story with watch I can’t slide left or right is it ok for watch?
Just a screenshot about what I mean
After beta 3 update brings this
Tried 2 times restarting watch shows same and after 2nd try watch restarted and this error disappeared.
(I am reporting this for just letting know what type of issues appeared).
So in beta 3 booting or rebooting takes a few seconds longer than in previous version on <> logo stuck for like 5-7sec than watch starts to work.
Sensor reaction to finger works uter slow when I slide down to turn on internet it react 5sec later after sliding down
Shows you have notification when I slide right from main menu shows 0 notification.
Charging icon doesn’t show when u charge watch(but watch is getting charged)
Hope yoy can fix this(((
(Correct me if I am doing something wrong)
In beta 3 can’t install instagram says device is not compatible.
For now that’s all I wanted to say I just updated it.
Yes install V1.0 ( local update ) then latest beta ( local update ) .
I think now it’s ok
Downgraded to 1.4 origin framework than with local updated did 1.0v than latest beta.At start seemed disaster but it was ok.
I’ll just downgrade to FAW 1.0 and wont update ever
Guess updating is not for me
Yep hence the big warning here in the support thread:
And also why the cable is shorter.
So it is easy to identify.
I now have all my charge cables labelled to avoid this problem
Makes perfect sense
sr i can’t able to found International FAW 1.0
can u upload the faw 1.0
@Rohit_Bhandari Have you even read the post at the top of this thread?
sorr sir why the hell i don’t read the whole thing
thank you very much you are so helpful thank
