As you will know some of your animated clockskins are not working on some of the newer watches ( depending on the firmware you have installed ) . Until this is fixed across all watches this is a temporary fix . This file explains how to manually edit your clockskins . Feel free to ask any questions . Thanks
Special thanks to -
@G1NT0N1C and @pablo11
Only
<color>1</color>
needs to be added ?
I didn’t told you??? Sorry Eric, I thought I allready did!
pablo11
October 12, 2020, 10:35pm
11
Thanks for doing this @Dr_Andy_Vishnu
It’s really useful for most because only new watches will have this fix.
However, I tested the new lem12 pro firmware and it is missing.
So I have asked them to address this and make it standard for all new devices.
The Kospet Power needs the fix as well.
Great job, thanks mate.
Your welcome . And lets not forget the SO8 v1.4
pablo11
October 13, 2020, 7:37am
13
Ha ha ha, heaven forbid…
do not work that file or someting wrong :
If you follow the instructions exactly as described it does work
i did it all as written, Didn’t you check the file
there’s a syntax error :
<drawable>
<name>digital20.xml</name>
<arraytype>60</arraytype>
<centerX>-56</centerX>
<centerY>46</centerY>
</drawable> ============> HERE YOU'RE MISSING THE <drawable>
<color>1</color>
<name>animated_image_1.xml</name>
<arraytype>62</arraytype>
<centerX>120</centerX>
<centerY>125</centerY>
</drawable>
