Where to order CD20Max / CD12Max from?
Get a S100. You wont be dissapointed
Well, yes…. However, they accepted orders / payments and then ended up being unable to provide the stock.
It’s a tricky one. Their business model is very different from what people may think, and once a payment has been made and it is in motion, they will fill the order - even (unfortunately) if it means substituting the request with a slightly different product.
It has always been this way, but recent circumstances that are not controllable have really highlighted this.
As a general rule of thumb and advice to all, don’t rush to purchase brand new design products. Advice is to always allow 6 - 10 weeks of proven sales before you purchase. It just pays to be patient. :+1:
Great point. I ordered three watches
CD12 Max W527 chinese version. Recieved a CD12 Max EU version with wifi hardware issue ( well reported ) and unusable firmware
S100 W527 chinese version and recieved S100 W527 chinese version :+1:
CD20 Max W527 chinese version. Recieved a CD20 W377 EU version
Full refund recieved for CD12max and CD20 sent in error
Got the CD20MAX Chinese edition in, and according to ADB it’s Unisoc UWS6152 chipped which is W527. The included USB charging cable didn’t have data (has 2 prongs), but I had a DW89 4 prong cable on hand that worked for data (without modification).
The RAM is 4GB and storage is 32GB (ADB reports 24GB, but everything else including AILIFE’s tool reports 32GB), and I don’t see any signs that either has been ā€œfakedā€.
AILIFE’s DW smartwatch developer helper got me USB data connection and wired ADB developer mode (Thank you @AILIFE!): AI LIFE / DW smartwatch developer helper Ā· GitLab
Order was from Shenzhen South Mountain via https://www.alibaba.com/x/B1cz9v
Total cost $85 (via Paypal on Alibaba) + $30 US tariff (via DHL delivery website)
Ordered March 9th, Shipping notice on March 16th, Received in Missouri, USA on March 19th.
USB Drivers working for me on Win11: SPD_Driver_R4.20.4201.zip Download SPD Driver R4.20.4201 (UniSoc Driver)
DW89 USB Charging Cable w/ Data I’m using (choose A2 option ~$5 shipped): https://www.aliexpress.com/item/3256808290674146.html
:clipboard: Device Specifications via ADB:
Processor (SoC)
Property Value
Chipset Unisoc UWS6152 (Spreadtrum)
Board Platform UMS312
CPU Architecture ARMv8-A (64-bit)
CPU Cores 4 cores (Big.LITTLE configuration)
CPU Type ARM Cortex-A55 (mixed variants)
CPU Implementer ARM (0x41)
Features FP, ASIMD, AES, SHA1/SHA2, CRC32, Atomics, etc.
Memory
Property Value
RAM 4 GB (4,000,556 KB / ~3.81 GB)
Swap Memory 3.4 GB
Storage
Property Value
Internal Storage 24 GB
Available Storage 22 GB (9% used)
Filesystem mmcblk0p42 (eMMC/UFS)
Display
Property Value
Resolution 412 Ɨ 502 pixels
Refresh Rate 62 FPS
Pixel Density 249.16 Ɨ 296.53 DPI
Logical Density 200 dpi
Display Type Built-in, secure touch screen
Camera
Property Value
Cameras 1 (front-facing/side)
Camera App Android Camera2
Sensors (6 Total)
Sensor Manufacturer Type
Accelerometer ST 3-axis
Heart Rate hx3918 Optical
SpO2 (Blood Oxygen) PIXART Optical
Vascular Pressure PIXART Optical
Fingerprint/Wheel Silead Touch
Step Counter SC Pedometer
Connectivity
Property Value
WiFi :white_check_mark: Supported (wlan0)
WiFi Standards 802.11w (Protected Management Frames)
WiFi Features Auto-roam, P2P, Pocket mode, coexist with Bluetooth
Bluetooth :white_check_mark: Supported
Bluetooth Name CD_Watch
GPS :white_check_mark: Supported (GPS daemon running)
5G :white_check_mark: Supported (persist.sys.5g = true)
VoWiFi :cross_mark: Disabled
Graphics
Property Value
GPU :white_check_mark: Present (DRI render node: /dev/dri/renderD128)
GPU Governor sprd_governor
Software
Property Value
Android Version 9.0 Pie
Android Go Edition :white_check_mark: Yes (optimized for low RAM)
Android Go API Level 28
Build PPR1.180610.011
Device Type Watch
Firmware Version 13.28.0
Security Patches June 2018 base
@Noispirit How do you root CD20MAX?
it is not possible to root this because the firmware version is too high you need 2025 version
bad news they have also found way to completely disable usb in system and in brom mode too so flashing will no longer be possible in w527
Ouch!!! That’s pretty serious prevention going on by the brand.
This is sad news,
i believe spd dump update will be able to get flashing again but not in near future (start from cd55max)
Well that’s a little bit of good news - for now.
Just curious @AILIFE - have you managed to build from source for the w527? Or is it not yet possible…?
i havent and will not do it, but someone else have done it prooving it is possible
for my custom system GSI will be used insted
someone have build the boot from source to get kernel SU
Sounds good. @Dr_Andy_Vishnu is sending me a CD20 Max that has the EU firmware image and it doesn’t boot after he tried to flash the domestic firmware (Chinese version).
So, I’m hoping to revive it and flash the Chinese firmware. So, I’ll need to get hold of the complete set of images (all signed I guess, which probably caused the failure).
Do you think this may be possible if all the required images are available?
Thanks :+1:
both firmware file is available
Just hoping that I can get it going so I can check out this w527 SOC and have a play with it.
Excellent, on T-gram..?
yeah here does not support send file even after rename
now have openclaw maybe can help organize the firmware files
Yeah I saw you testing openclaw on T-gram. Seems to be working OK :+1:
CD12max :rofl::rofl:
@Dr_Andy_Vishnu Sorry mate… yeah - what you said :joy:
I don’t have a Danny at the moment mate, so whatever you say is reality :+1::+1:
As far as getting it working again goes though, as with all the CD models, it will be interesting and may not end well. They all seem to have issues of some kind.
It looks like they need to do some work on the board and chip design / layout. To be honest, I’m thinking that these have been released a little early and may not be ā€œproduction salesā€ ready yet. This could be partly why they are harder to buy, as well as the shocking increase of the prices. I heard that the S100 price has gone up significantly (in last couple of days!)
