Where to order CD20Max / CD12Max from?
By the way @Noispirit
Is this OS something that needs to be installed, or are you saying that this is the stock OS?
Pablo11
Excuse my ignorance, but I have no experience with this chip yet.
But it’s a happening thing. I (and Wiite) will hopefully be getting hold of this very soon.
It’s a very promising chip indeed :+1:
First watches came with Divo system that is still A9 but not called Noemie
Then they started to sell them with NoemieOS, around November. It’s still A9 but they added some features like AoD with triple tap to wake, or making the Desktop mode by default instead of the watchface mode.
The thing with CD watches is that they will sell you a build that can be updated for some time, then if you want new updates you will need to buy a new watch.
In my case I was able to format the whole firmware and change the partition scheme so I could install the first NoemieOS firmware, but more recent builds like 20251217 or 20251230 I won’t get them unless I buy another one
Yes it’s true
i heard there was a bug if you use english th system will crash
cd12max camera is not the same level as s12a, the dynamic range is very bad
it is true, after flash GSI it maintained 4/64
ok, before i lost my patience how buy that?
I saw a cd12max on Alibaba, but I’m not sure if it’s the one with Android 13 and unisoc w527, If you want to buy 1000 of them and try for us haha, or just wait for someone to buy them in bulk and sell them on AliExpress,
Reading the specs, I saw that they W527 but with android 9
w527 comes with Android 9 as standard I believe? To be honest, as long as as you have GSI it shouldn’t really matter. But as @AILIFE says, there may be a bug in the English language setting… Apart that, I think it should be ok.
W527 comes android 9, can run up to android 14
in latest firmware you can use english
but here is some technicality so it is a bit laggy(long story short the display is upside down and have to be fixed with software rotation andis causing a bit of lag)
226 firmware can notroot for now because the new signing key is not released yet and i dont have it either but you can still install custom ROM they do not check for that
It will be better after the Spring Festival (Somewhere in March). SUPPOSEDLY they are working on a European version with GMS, but dunno I can´t confirm it.
Buy through superbuy if you’re desperate
Is this a rebrand of one of the two watches discussed in this thread. It claims to support finger print unlock and has a unisoc processor.
No. This is not the CD20 max. Different chipset
The CD20 max with new chip can be bought here but only after the 25th
https://www.alibaba.com/x/1lALAWJ?ck=pdp
With Android 9 : no thanks..
Minimum order is 1000 pieces. Maybe Vwar will rebrand and sell it.
As explained previously
VWar is a brand - not a manufacturer in that sense.
Yes, they could bulk buy and brand it, but then again so could anyone else. As long as they negotiate with the owner of the board design and the factory producing it - no problem at all. In this case, most likely the guys from the Alibaba link are producing the device - but they may also be a “middle” link in the chain (a bulk buy marketing company). I’m sure a few brands will be interested once the lunar new year is over - 25th Feb.
They wil sell you one. I asked
