Thanks for the reply.
I figured they couldn’t be published and I find it right.
Of course I would like to do this for personal use and I have no interest in publishing them.
I don’t even know if I’ll be able to do it …
It would be even better if someone more experienced than me did it on my own, but I doubt anyone willing to do it …
WFD is currently unable to do this. It has to be added manually.
Here’s a guide on how to do it:
Thanks for reply, I’ve already done it, successfully!
I have another doubt, would someone be able to explain to me how the X and Y coordinates are calculated to insert the various interactive buttons in the watchface? is there a sort of map with the points of the quadrant to be inserted inside the XML file?
Oooook, perfect, thanks! this is what I needed
Hi
since the last update of my Kospet prime, the circular bar battery does nt work anymore.
Any idea???
Thx
The newest face engine is working slidly different as the old ones. Some faces have to be redesingned.
An other way is to flash back to the old firmware.
Thx for reply, i try to redesigned but that doesnt work, the bar is already 100% or when is ok the bar is not in place
There are some new araytypes: AT61 (charging animation without charging image) and AT63 (charging animation with charging image). But you have to add it manually to the clockskin XML, because UL can’t handle it at the moment.
Ul or wfd ?
Sorry, WFD can’t handle it. UL works fine.
Stocklauncher, too.
Good morning all . If you look at the top post we have posted the newest version of WFD V 0.14.2 beta . Please note this version is incomplete and may never be completed . However it does have features some of you may find usefull . We have lost contact with the developer and hope he is fit and well . Our best wishes to @Marco_Ferreira .
Have now tested the new version v0.14.2 beta something. The ARRAY 100 functions work quite well. Now you don’t need to extend the xml-code by editor. While testing the following question came up: the new functions for the “autorotation”: “balance Wheel and steps”: can you use these functions on the Genesis ( standard launcher ) ?
How can I write some text in a watchface ?
Can you clarify your question? Do you mean a static text? or do you want to display a time as text, for example?
clockskin only supports images, so you have to put your text on an image.
Hi, @Marco_Ferreira great work !!! I have made couple of faces with your software.
I am not able to download 14.2 , the link is not working, so please do needful. Thanks in advance.
Best regards Mehul
