I think I have worked on something similar of sort when working with a weekday panel that illuminates on corresponding day. Thanks for the hint.
How to add utc time in wfd
Accidentally rewrote an existing xml file with another. Is it possible to retrieve the xml from the exported zip file?
I don’t think so. WFD combines image files when they are compressed, so the original .xml file is lost.
LOLZ! I’m copying that!!!
(ps maybe eric chrocemore will have a better answer for you)
No you cannot . Sorry
OOps… I meant Marco Ferrario not Eric SORRY!
Utc is not supported
Sure, the xml are exported in the zip.
Yes, but they are altered somewhat aren’t they?
I know… PPPffftttttt. (I am an idiot)
I am an idiot too and the there are many. Xmls in the zip.
Yes, but they are altered to match the newly combined images I think.
It is but you cannot load the one in the zip back into WFD . However you can alter the .xml file as i have done today adding things like array 100
Alright restored by now. But I was wondering what does the "Image List " drop down list do?
Marco - WFD runs out of memory and crashes when designing a fairly big animation (60 images). Is there any way to increase its memory?
60 IMAGES?
It happens when you use animation ( . Gif files )
Tim’s right… One image for each minute…
