I’ll wait until you add them (if you do). Even if it means it’s only compatible with Universal Launcher. Since my friend and I only use universal launcher. Cause it’s good stuff!
Edit: Maybe an unused arraytype that could be edited into the XML.
If you are looking for a solution to do it for stocklauncher, here is the solution:
It allows to display 12/24 pictures during 12/24 hours.
Hello,
I use the “stocklaucher” in my Zeblaze Thor. I try to create a car speedometer as a clock.
( see attachment ).
I use the autorotation multiplier -3 to display the hours ( speedometer needle ).
In the stocklauncher of the Thor the hour value is displayed wrong on the clock, in addition the clock runs backwards. If I display the result with the clockskin browser, then it is ok in the preview of the universal laucher and ok in the X series stocklauncher, but not in the KW stocklauncher ( seems to be the same as in my Thor ).
Is there a chance to get it to work in the stocklauncher of Thor or is it time to switch to the Universal launcher ?
It’s always time to switch to UL.
Change the rotation direction for your kw. Then it should work on zeblaze and kw. If you are working with two or more layers for the hand, you will have to create some empty extra layers to make it work. And maybe you have to change the startpoint of your rotation. It’s a little bit tricky, but it’s possible.
But, by the way- UL is always a great choice.
@eric : of course you are right .
@G1nton1c : changing the rotation of the direction has no success. yes, I have to change the startpoint, but this was not enough for my zeblaze. I think i have to go to UL anyway…
I tried to upload my xml file, but this was not possible ( format not allowed ).
Hello, this is a really great program. I use it to create my own clock and has become perfect, but I have the following problem. By putting the arrow in the hour I use the quartz option. This thing works only with Universal Laucher, is there a way to work without it or if it is installed, not to change my original design of the clock (menu and other).
Thanks in advance for the answer
Trying to download, but clicking links brings-up a .jar file that doesn’t open???
To open a jar file on PC, you need the software Java Runtime Environment.
how to open extension .watch file with Watchface Designer?
I don’t think you can, use the watchmaker app for that.
es it’s possible to convert .watch file to clockskin?
If it’s not protected, you can extract the pictures and use them to build a clockskin version FOR YOUR OWN USE. But you are not allowed to publish anythink without the permission of the original designer.
Thank you. how extract the file. Watch?
Just unzip it like a zip file.
Thank you. I am happy this forum is good.
@Marco_Ferreira I hate to be a bother, but is there any news on the 0.14.2 beta or full release? I have some cool ideas, partially based on the THOR DUAL faces you posted, but I cannot try them out until the new version comes out. I have some ideas that I can do until then, though.
Hello friends! This program is truly extraordinary! I ask if it is possible to use images to have an hour or minute hand etc … Or can it only be created?
Yes you can . Any image can be rotated this way . Or you can make your own .
