Watchface Designer
Feb 16, 2019 3:53:06 GMT manuj said:
Hi Marco, if I'm useing the digital indicator of WFD as a power indicator it's dislocated and split in 2 parts on some watches. But if it's set for example on seconds or steps (0 to 100) it's in the right place. What I have to do to keep it also in place when useing it as power indicator? Thank you for helping.
To use it in kw stock launcher, you’ll have to export as a tweaked clockskin and activate the last two tweaks. It’s not just the power that is affected. The rotation direction is also affected if you have multiple rotations of the same type on different directions.
Congrats on the winning, by the way
Ok I see. I was afraid to export as a tweaked clockskin as it’s then probably only working with the set resolution and may not working with some peoples smartwatch. So this time I solved the issue with an other little trick. But that’s good to know for my self and the next time. Thanks.
And thank you for the congrats, I’m very happy.
there is a my question:
is it possible to make second system on WFD on video at 8:40, green radar face?
my opinion to make it : a gif with 60 frames…
how did you solve?
where is everybody! this place turned to cemetery! ash to ash dust to dust
I still come here, from time to time
You are here, very nice! but where is my question's answer? ↑↑↑ ▲ ☻
I don't know if your question is for me, but I've already told an answer: /post/32607/thread
thanks Marco, actually i have 2 questions, one for you:  /post/32634/thread
Here it is:
I love the detected radar sweep!
Here it is:
excellent work, wonderfull very thanx!
i wonder, can be made seconds that numbers moves around watchface in the same video?
plus, your WFD program has more effects and 2 digital indicator buttons, different than mine? (v.0.14.1)
Here it is:
radar_map.xml (90.83 KB)
hi excellent work, I would like that in addition to circle
of energy you could use the circle in heart rate and climate, thanks again
Please
radar_map1.xml (89.3 KB)
Please
Good work !
Mar 23, 2019 13:45:27 GMT serdar said:
Good work !
By mpmf tutorial ))))
mpmf, is it possible to do rotating steps like in Samsung?
Thank you.
Feb 28, 2019 18:07:13 GMT 2 serdar said:
Feb 28, 2019 1:17:13 GMT 2 mpmf said:
Todavía vengo aquí, de vez en cuando
Estás aquí, muy bien! Pero ¿dónde está la respuesta de mi pregunta? ↑↑↑ ▲ ☻
Good night friend excuse the question but some update?
Estás aquí, muy bien! Pero ¿dónde está la respuesta de mi pregunta? ↑↑↑ ▲ :slight_smile:
Thanks. I found out it myself.
