allelimo and mpmf, I do sorry for my hurry written and make you misunderstand. The latest sample of mpmf woks fine with default launcher of latest firmware (no universal launcher) also.
Sept 21, 2017 15:12:57 GMT 1 bertorelli said:
Does anyone know how to show only the AM or PM from the time?It looks ok in Watchface Designer but doesn’t show on the watch after installing.
The time also seems wrong and always shows the 24 hour format (14:30 for half past 2) and not 2:30 PM.
Have you checked that your watch Time setting is not set to 24h ?
thanks for solving my problem and thank you for introducing the speedometer square
Sept 22, 2017 6:42:28 GMT 1 ricktop said:Sept 21, 2017 15:12:57 GMT 1 bertorelli said:
Thanks for the tip.
It was on 24h but after i changed it to 12h nothing changed and still the AM/PM doesn’t show.
Sept 22, 2017 3:41:41 GMT 1 vrmagician said:allelimo and mpmf, I do sorry for my hurry written and make you misunderstand. The latest sample of mpmf woks fine with default launcher of latest firmware (no universal launcher) also.
ah ok, good news. mpfm, do you mind sharing the solution? I don't think wfd is opensource, but I'd like to add the "kw88 compatibility" to csm too
it would be good in a next update the speedometer to insert over the dot, square, also line , it can be useful
maybe I ask too much but a nice drag & drop?
and the likelihood of creating file.watch?
maybe too much meat on fire
One software to do everything would be great
Sept 22, 2017 8:31:22 GMT 1 bertorelli said:Sept 22, 2017 6:42:28 GMT 1 ricktop said:
Thanks for the tip. It was on 24h but after i changed it to 12h nothing changed and still the AM/PM doesn't show.
Here is a demo watchface you can try (this is the WFD project, not the clockskin. just export it with WDF, latest version). It works perfectly on Finow X5 Air with stock launcher (and settings to 12h watch) and on CSM. It does not work correctly with Eric’s launcher (no AM/PM symbols), so maybe there’s a bug to be solved there.
AMPM.xml (9.73 KB)
Sept 22, 2017 12:52:30 GMT 1 qqdevil said:
it would be good in a next update the speedometer to insert over the dot, square, also line , it can be usefulmaybe I ask too much but a nice drag & drop?
Ok, line can be added.
What do you mean with drag & drop? What would you drag and where would you drop it, and what would be the effect of that? You already can drag items around the watchface.
The likelihood of creating .watch files are still low, at least for the near future. I still need to add support for more things before I can even think on .watch faces (such as bitmap fonts, for instance). The way .watch works is very different of the way clockSkin works, excepting the fact that both are layer based formats… Also, supporting the whole scripting thing would make WFD too specialized. If I make it, the .watch face will have only standard scripts and the user will have to modify them (if they wish) outside WFD.
One software to do it all, one software to rule them all… And it’s mine… My precious… Ooops, Sauron is looking for me.
ahahahahahahahahahha
drag & dop in the way insert the images directly inside and automatically create the image level
mpmf , just 1 bug found in your sample (that I’ve tested) is the week’s wrong, in the picture should be Saturday instead of Sunday.
This is great! Thanks a lot!
Sept 22, 2017 19:51:38 GMT 1 mpmf said:Sept 22, 2017 8:31:22 GMT 1 bertorelli said:
Here is a demo watchface you can try (this is the WFD project, not the clockskin. just export it with WDF, latest version). It works perfectly on Finow X5 Air with stock launcher (and settings to 12h watch) and on CSM. It does not work correctly with Eric's launcher (no AM/PM symbols), so maybe there's a bug to be solved there.
Added this feature in my launcher, it will be in next release...
Very, Very nice tool. I am excited.
The only thing I didn’t find is the symbol, when charging the clock ( 99 ). May be I am blind.
Keep on the good work.
Hi, mpmf. This tool is awesome. Thank you very much for your effort. I have a little problem, probably due to my lack of skill… I´m trying to create a watchface with an image that changes depending on the battery level. The image should be centered on the lower half of the watchface.
Problem is, although in the computer looks nice, when installed in my watch (Lemfo LES1) I can only see half an icon on the left and half an icon on the right of the screen. I´ve tried with different icon sizes: 400x400, 400x100, 100x100… the result is always more or less the same.
Any hint? Thanks in advance!
Sept 24, 2017 11:25:01 GMT 1 mgk said:
Very, Very nice tool. I am excited. The only thing I didn't find is the symbol, when charging the clock ( 99 ). May be I am blind. Keep on the good work.
Yes, WFD doesn't support it... yet.
Sept 24, 2017 13:22:01 GMT 1 cesarm said:
Hi, mpmf . This tool is awesome. Thank you very much for your effort. I have a little problem, probably due to my lack of skill... I´m trying to create a watchface with an image that changes depending on the battery level. The image should be centered on the lower half of the watchface.Problem is, although in the computer looks nice, when installed in my watch (Lemfo LES1) I can only see half an icon on the left and half an icon on the right of the screen. I´ve tried with different icon sizes: 400x400, 400x100, 100x100… the result is always more or less the same.
I’d have to look at the .xml to get an idea of what’s happening. Can you send it (or an example where what you describe happens) to me?
Sept 25, 2017 10:55:31 GMT 1 mpmf said:Sept 24, 2017 13:22:01 GMT 1 cesarm said:
This is how the watchface looks on the creator:
The JRRT logo is the image that varies depending on the battery level, going from darker to lighter. I have 10 different images, one for each percentage level. And this is how it looks on the watch:
Seems that half a percentage image shows on the left, and other half on the right.
Should you need the xml code just let me know.
Thanks a lot!
this can probably be solved with the masking tecnique used for the fake “day hand”, see here:
plus.google.com/u/0/112553839840359721091/posts/KqKNP3EUXSq
Sept 25, 2017 12:06:33 GMT 1 cesarm said:Sept 25, 2017 10:55:31 GMT 1 mpmf said:
Should you need the xml code just let me know.Thanks a lot!
This bug exist in all watches, in the clockskin engine except finow x and + series . You need draw the battery images one half imagesize, and will correct display.
Sept 25, 2017 20:24:30 GMT 1 zsolt m said:Sept 25, 2017 12:06:33 GMT 1 cesarm said:
Sorry, but my English is not very good. What does exactly mean "one half imagesize"? You mean 200x200 for a 400x400 screen?
