Have you read the posts up above?
If so, then you know as much as we do ![]()
A link to the available versions for people who do not use the play store:
@pablo11 Yeah, I tried to follow but thereās a lot of messages to go through. I also checked your link to XDA and found that he hasnāt been active there in quite a while either. Itās a little unfortunate because it seems like a nice app, particularly when compared to a lot of the included smartwatch apps. Iāll try just downloading and installing the apk from your link but Iām guessing the discussion above about a permission change or an android API change may have made it unlikely to work and thatās why it says itās not available for my device.
It did let me install the APK. It will connect fine until the screen turns off. I tried all of the config on the FAQ for the app but some of it is not done the same way in Android 11/13 as it was when the app came out. I can get it to connect by turning off/on Bluetooth. I think it has something to do with the watch being a phone instead of a headset so android does not want to maintain the connection.
Itās the power saving options on the watch.
In the Optimisation app for the watch, check the Clean Task is disabled and the set permissions for watch droid to run in the background in the watch power settings etcā¦
Same as a mobile phone.
You can can search for ābackground appā in the search tool here on the forum for more information.
@Dr_Andy_Vishnu created a straight forward guide which pops up when you search
A post was merged into an existing topic: Android 11 is here! Lokmat APPLLP 4 Pro and LEM16 Z40 models
Even than droid loses connection,even in premium.
Ronald
Holland
To allow apps to run in the background on A10 follow the following instructions from the watch menu :-
Settings - Apps and notifications - special app access - unrestricted data - turn on app
Settings - Apps and notifications - battery optimisation - all apps - click on app - dont optimize
Settings - Apps and notifications - see all apps - select app - mobile data and wifi - make sure background data and unrestricted data usage is on
To allow apps to run in the background on A9 follow the following instructions from the watch menu :-
Main menu - optimization - clean task - tap on the white text - then tap the green circle on the app you dont want to sleep when the screen is off .
Also do this -
Main menu - settings - apps and notifications - special app access - unrestricted data - then tap slider on the app you want to have unrestrcited data
Works fine for me if set up correctly as @Dr_Andy_Vishnu says.
Same here. Flawless ![]()
When watch goes in"sleep"connection is lost.
Ronald
Then you cannot have followed the instructions properly
I Think I dit not do well,
My English is not good enough I am afraid
Ronald
Holland
Donāt worry about your English, buddy. It is in order. Many here are not native speakers.
Only an explication too understand is a problem,I would like to have the lancher to but It does not work out like the YOU TUBE film.
Ronald
Holland
If weāre talking about universal launcher, thereās two applications to prevent from being optimized : watchclockskin and preferences.
Yes watchclockskin ,I tried twice but no succes.
It is on the watch again,but I have only one watchface with it.
Al my other faces are gone.
Thatās normal, because Universal Launcher canāt display stock faces. But you can download and install thousands of faces here.
By the way: the stockfaces are not deleted. They are still there. They will be back if you use the stocklauncher again.
Thank you
Ronald
