Is stocklancher something else as Watchclockskinlauncer?
Now I have that on the Lokmat.
Ronald
Ronald
The stocklauncher is the one that is installed on your watch. It’s a part of the firmware.
The universal launcher is an alternative launcher that is also able to display watchfaces in “.watch” format.
Oke,thank you,I learn a lot this way.
Just ONE problem and I can use your laucher.
The Watchfaces are all in zip.
I can not make it a working watchface like APK.
Is it possible to explain that too.
Ronald
Place the ZIP files in the folder called “Clockskin” on your watch. (If there isn’t a folder with that name there, create it). For example, you can move the ZIP files to your watch with a computer via USB.
I have no PC only tablet.
Is that problem?
thera are no apk’s?
No apk.
You can use your tablet to transfer by Bluetooth.
Just use FX Explorer or similar.
I try again,thanks.
In witch place are the watch faces zips.
If I try to download it is not longer there or not permitted.
Ronald
oke I will watch it
No succes yet but i go on.
Where can I find the watchfaces?
Ronald
Are you serious ? There are hundreds on this forum .
O, i just have to look .
I toght maby on one place on the site
Try exploring the categories and you will find the faces easily.
There are quite a few videos on YouTube about how to use the Universal Launcher.
You must ensure to grant ALL the permissions required and then go to Apps in watch settings and set Universal Launcher as the default launcher.
Please take some time to read and research about universal launcher because it is getting very difficult to help you any further.
I’m sure you will succeed once you have taken time to look for all the information you need.
Cheers and good luck ![]()
I will.
I like the watchskinlancher it hase many possibilletys.
Thanks for the help.
Ronald
You are right
Thanks,
It makes a lot of difference to know what the issue is.
Thanks for your honesty ![]()
Hello everyone, wanted to know are any way to make smartwatch show who is calling you?
You have to install this app on your android phone (not on your watch) and use it instead of the stock app:
-https://play.google.com/store/apps/details?id=com.google.android.dialer
