you must wait until the battery on your watch is completely drained, launch the sp flash tool and press the start button on it. then connect the watch to the dock
I don’t know how to write in English so you can understand me
that is, with completely empty batteries will I start the sp flash tool ??
how will it open after it will not have batteries ??
Thank you very much, and my English is not good
Can you charge or not.?
First things first.
no i can not charge it.
the battery icon is red, sometimes it turns blue for 5 seconds and then the screen turns black
as long as the battery icon is red the screen is open, as soon as the battery icon turns blue the screen closes in 3-5 seconds
It is supposed to do that.
The blue icon is designed to time out after a few seconds.
Leave it plugged in to charge and very lightly or quick press the power button. The blue battery icon should show again but it will go black after a few seconds.
This is how you check charging progress.
I put it in the power to charge. the battery icon is red. I do not know how to make it blue. to leave it so red and at some point it will only turn blue ?? When I shake it, the screen turns off and turns black. when I take it out of the charger and put it back in the picture becomes red again
sorry for my English
When the screen goes black and it is on the charger - what happens if you just light press the power button? Quick press.
the screen will not open . I have to press it many times and with force to make it white for a while and then show the red image of the battery
I have it in the charger for 10 minutes without disturbing it and the screen is open and the icon is red.
if i tease it it will go off and then i will have to try many times to make it red again
I shook it a little and the battery turned blue. to leave it like this without hurting it ?? is it charging now ??
if I tease it I am afraid that the screen will turn black again and then again from the beginning the battery will turn white and red
Don’t touch for one hour now, it should be charging.
I think so too
I bought a Lemfo LE10 watch because I couldn’t turn on Kospet Optimus Pro or change the firmware in it .
But after the battery was completely drained,
I was able to do it. Everything must be selected in the sp flash tool.
Bootloader lock.
Yes
I hope so.
I installed the roms from here the v4 and v2.7 and the v.3 from the official site
why this happened I can not understand
5 days ago I made my own kospet prime and everything went perfectly and in 2 minutes it was done
this is my cousin and i got to do it because i saw with mine that it is easy
I think it may be that you flashed Optimus firmware.
Not Optimus Pro.
V3, I mean…
I downloaded it from here
https://www.kospet.com/support/39.html
most likely, it is installed on Optimus Pro watch firmware from Kospet Prime watch
I downloaded the 2 roms from this page above and the other from the link I put which one above and it is for the kospet pro 3/32
Yes @anon73267173 quite possible.
And soon we will see if bootloader is locked because of this.
@Gthom if watch still has not changed in one hour or so then you must load the v4 firmware from the top post.
Load it in flash tool and use firmware upgrade option.
Connect the watch to the PC and click download in flash tool.
Then press power button on the watch to try and open the boot loader.
That is all I can do.
I am away on holiday.
