No problem, anytime
Holy cow really??? I will need to check my Kospet optimus pro now thanks!
A reboot does not fix the problem?
Nordic chip should sync up with Android on boot
I have tested my Optimus Pro and the long standby time is same as Android watch time.
Have you messed around with the time zone settings at all?
I made it sync by changing the time setting from auto to manual and back to auto as a user mentioned it before in another thread.
take it here
Jolly good
I tested mine and it was OK so I know that there is no issue.
Just FYI - the 2 different clocks sync on boot.
While I’ve tried to follow this thread, it became way to technical (too many bunny trails) for my interest. I just received an OTA with build Hope_B_20191024. How is this different from the version mentioned on the first post? Funny thing is there is no mention of this version on the Kospet site. TIA…
I asked it here 9 days ago. Think nobody knows. Read there were some changes like the new kospet firmware mostly in Settings menu.
Could you be more precise? I do not understand what you are talking about.
How is Hope_B_20190320.7z (first post from @pablo11 different from Hope_B_20191024?
The build version of the firmware in the op is of 20th march, and the updated one from the ota update is of 24th Oct, so there might be big fixes (or new bugs lol)
I don’t think kospet maintains a changelog, so you can’t exactly determine what all is different apart from the obvious changes
All I was told is that this most recent update has very minor changes.
I’ll post the full version once I get 5 minutes to do it.
Cheers.
Thanks and best wishes/safety.
Hi…
I had flashed V3.0 FW after installing the latest and reset equipment I found that the Ring Volume is disabled and cannot adjust the Ring Volume. See the attached JPG. Please let me know you had this problem. Thanks and appreciate your response.
You must have ‘quiet’ mode turned on, go to the toggles page (swipe up from homescreen, then go to the left) and disable it (top left button)
qmeghgoswami… Thanks for your reply. From home screen if I swipe left it is notification… From home screen (watch display) swipe up is Fitness Step data, Can you msg me step by step pls.
Sorry, I meant to say swipe from top to bottom
Thanks … I got it and now it is ring volume is adjustable.
Greetings from Poland!
Good morning guys!
I am so sorry for this silly question, but after update to FV 3.0 and install watch droid assistant I lost options to turn on/off HR monitor for skins, or adjust the skin size.
Any one would be so kind and help me to get it back?
Regards!
If you are using universal launcher you should ask in the launcher support thread.
