Ok sir, @Eric_Crochemore, thanks. it’s unable to speak the word( Forty ) only. Rest is fine. Hope you will find the solution. Thanks for reply
And my kingwear kc06 are still show 0 steps in stepcounter(
Hello Eric, while testing the version 3.2.3 I found an issue and hope that someone else confirms if it is a general one. On my Kospet Prime I am now unable to go to the power saving mode (which disables almost all the functions except for a basic digital watch) by pressing and holding the power button. Pressing the saving mode icon doesn’t change anything.
And it was working before ?
yes, in the previous version
It was “fourty” in my engine instead of “forty”. That explains it.
New version :
Thanks for your time and good work. What is new in this version?
It’s written above, just a correction on a watchmaker script behaviour.
@Eric_Crochemore, thanks sir, I am downloading the new one. After testing I will give you the feedback. Thanks for co-operating.
Dear Sir, @Eric_Crochemore very very thanks. It is now working fine. Problem solved. It was impossible to work without your help/co-operation.Thanks a lot.
Hello everyone,
I have an Optimus Pro kospet with UL.
I wanted to know if it is possible to insert a widget for the steps or for the heart.
At the moment the only way I have found is to put one WF and it contains them.
thank you very much, and congratulations on this beautiful launcher.
Max
It is not possible to use widgets in watchfaces. But information such as heartrate, steps, distance and calorie consumption can be displayed on the watchface itself.
A shortcut to an app is also possible.
Could you give me the link to the watchface you are talking about?
sorry, I explained myself wrong.
I know that it is not possible to insert widgets in WF.
I wanted to know if with UL it is possible to have a widget with steps or heart rate .
Eventually you can show me an app with these widgets.
Thank you very much and sorry my poor english
Max
You can add health widget in the widget section of the launcher.
Yes, but not the heartrate- app. I just had a look.
@Mixmaxmux Don’t worry mate, your english is fine. I just installed the app gstep. It works and you can add it as a widget.
Thanks for the info.
But I can’t find the healt widget for the Optimus Pro kospet in the widget section.
am I doing something wrong?
Now i use the gstep app as suggest by @G1NTON1C
CIAO.
Max
hello,
I use UL on an Optimus Pro kospet, I am very happy and I wanted to congratulate you for this splendid Launcher.
I am interested in the Heart monitoring feature, if enabled it activates every time the screen turns on.
Now during the day, often moving the arm, the measurement is always active.
I wanted to know if it was possible to insert a configuration that allowed to select the minimum timeout between one reading and another. example if I enter 0 it works like the current one, if I enter 15 it allows a reading every 15 minutes at least and so on.
This would allow for continuous monitoring and battery aid. It’s just a suggestion.
Thanks again for your wonderful work.
Max
Hi Eric, if you want to accept one suggestion about your launcher…
in the first img. the contrast between text and wallpaper is perfect, in the other two apparent in the screenshot is ok but in the watch is very hard to read the text.
Can you change the wallpapers in the notification screen???
Thank you…
Dear Sir @Eric_Crochemore, thanks for regular co-operation to us.
Here I am writing to you after a long day. As per discussed previously regarding talking clock watchface problems. You have rectified my problem from Universal launcher 3.2.3(latest)
But to day I found one another problem in the launcher 3.2.3 (latest)
The launcher thinks 12:00 PM to 12:59 PM as AM. After 1:00 it Speak normal like 1:00PM.
The launcher read the time as “AM” between the time mentioned above.
There is no problem in .watch face file. It read correctly in Android Mobile having installed watchmaker app.
So again I heartly request you to see the matter if you would have some spare time.
Hoping you will see the problem.
Thanks with regards.
