You can try L Launcher on this forum
Thanks for the reply i did try and install both 1.03 and 1.06 and both said trouble parsing the package
so i dont think it works on the Lem 4 Pro
Would it be at all possible to add a configuration option to disable the stopwatch and calculator applications?
Hi
I tried using a watchmaker file but the dim mode does not display any dimmer it just displays the dim objects ? is that correct
yes it’s correct.
ok thanks for the reply
Dear Sir, L launcher is in it’s basic/childish stage. It is not working perfectly like Universal launcher.
Dear sir, I like to ask some question regarding universal launcher 3.2.2 . It is working very well in my Finow x7 android 7.1.1 OS. I am now trying to use .watch faces and it is also working fine.
But just some days ago I find .watch face with chime facility and some with talking time. Now I had tested it on watch. The hourly chime function is working. But another function talking functon( means speak time after taping on screen) is not working. But the same function of watch face is working on watch maker app installed on mobile set. The mobile set has android 8.0 and watch had android 7.1.1
Here I request you to ask a question is it due to univerasal launcher problem or any other things. Because universal launcher is working fine. Just this problem i find that the .watchface did not speak time in watch where as it is working fine in phone. I know this is not the forum for .watch or wear os. But your launcher support wear os ( .watch face file) I am curious to know the exact problem in this regard. Hoping you will reply. Thanks
UL has a free implementation of watchmaker functions, this one is unknown to me and so not implemented. You can share the skin so I can have a look, but I’m not very optimistic in supporting it.
I am sharing the link.please see the problem.
These are two. Watch file.
I had also installed a talking clock.apk. the apk was working. But. Watch face talking tap not working. Thanks. I am sure you will find the problem.
Tap below sony for talking time. And second one tap on time or date.
Well, i’ve got it working, there was a bug. I’m testing and will publish a test version soon.
Dear sir, thanks. Very happy to hear and will wait for updated version. Thanks again for your co-operation.
Here is the test version :
it works perfectly, I don’t knew this possibility.
Is there the possibility to insert voice in tap and how to add icons as wifi and bluetooth,when active,in a face with WD? no ,right?
Thanks Eric for your work and fast update.
Dear@Eric,thanks, I have downloaded and tested. It is working superfine. Here I like to say that I have no word to appreciate you for this work as well extremely fast. Thanks. I am replying after full test and now it tell the exact time of dial after every tap.
Dear sir, I want to tell you there is some problem in test version universal launcher 3.2.3. As I had requested to look in the time talking. Watch face.
Here it is working with some problem . The peculiar problem that l am unable to understand that it tell half word of time when the minutes niddle between 8.00 0’clock to 10.00 o’clock. Like the time is six forty, six forty one, six forty two. It tell six ----, six ------- one, six-----two. The forty word is missing between forty to forty nine. Again after 50 it is telling normal time like fifty one, fifty two and all. It happen in every hour either one to twelve. There is no problem in. Watch face skin. It is working normal in phone. In also watchmaker app installed on watch. I have updated app google playservice, text to speech, accessibility etc.but did not get success I am unable to see the problem. It may have some minor bug in UniversaLauncher test version 3.2.3. It’s unable to speak the word (forty) while telling time.
Hoping you will do some thing . I am not a professional, but these are my interest to solve anyway.
Hi.First of all let me thank you for dedicating your time to develop this application. I have noticed something while using this launcher. Changing the wrist turn on timeout values doesn’t make any difference and the turn on time out remains almost 4.5 seconds weather you choose 0 or 10. Is there anything I missed?
Another question please. does the weather auto updates itself or should we activate some option for it to do so?
Thanks again
Update,
I believe I knew the answer to the first point. I disabled the default tilt to wake gesture and activated the one that comes with the launcher and now the screen remains on for a longer time when I raise my hand. Good job bro
Dear sir, please reply my previous post, is it the problem of my watch or UL 3.2.3 ? If it is the problem of my watch, then nothing to do for me except to change the watch. If it will be cleared by your side, I will thought to change the watch.
Please spare some time from your busy schedule to reply my questions.
Please be patient. We all do this for free. He will answer if he find some time. No need to push him.
It’s probably a bug in UL, the watch has nothing to do with it. i’ll look.
