I have a Prime,removed google widget and insert watchdroid,clock,weather,steps,sleepbot widgets and it works fine.
thanks
Just reboot the watch it will be fine.
Did that multiple times. Didnât work.
RK
Could you, by any chance, implement support for the HR sensor in Microwear H1? Would be neat, as right now it does not work. Attached below is its stock launcher, which contains some code for the heart rate monitoring:
igmn.tk / storage/Sx/KctLauncher.apk
(remove spaces)
Thank you in advance
Thanks for the source code, it uses a non standard sensor, iâve added it in this version. I have no idea if it will work. Let me know :
Doesnât seem like it. I have the little heart ticked in the double tap menu, so itâs blue, as well as the Heart Rate Monitor is enabled in settings.
Additionally, i forgot to say that Raise to Wake doesnât work in the launcher, only the system one works.
Iâd kill for a way to have the stock sleep tracking, heart rate, etc controls in this launcher, i like it way more than I do the stock one, but eh
Also, suggestion: gradually transition the brightness to the minimal level in the AOD mode, so it doesnât drain the battery nearly as much. It wonât help me, because every single AOD thing draws battery like crazy for me (1% per minute or so), but may help others
Can I kindly get some help please.
I have a Kospet Prime. I have wrist gesture shut off and its working properly. However, when I install UL, wrist gesture still continues to work and I canât disable it even when I still have the prime launcher still showing disabled. Iâve tried changing the UL setting to 0 seconds, etc. with no luck.
Thanks in advance!
I now have Universal Launcher installed & am trying to get used to the new behaviour. Itâs amazing how almost the entire interface of my watch has changed from this switch. Is battery drain likely to be an issue with this launcher, compared to the standard one?
No . You will have no battery issues at all with this
I found out the problem. The issue was with 1 of the .watch faces.
RK
Could you offer a link? I think Eric will like to have a look at it.
I donât have a link. I downloaded it from one of the MeWe groups. Please let me know if I am allowed to share the watchface here.
RK
Please send it to me via PM. Thank you.
Hello. Great job. I read all the branches about UL. So I did not find the answer. Kospet Brave 2/16 mtk6737 Android 6.0. Clockskin faces do not display Steps, distance, calories. Is there something wrong with me?
It should work, you just have to adjust the default health settings.
Thanks. Apparently this is built into the stock. I did not find such settings. I will use in parallel stock and UL. Thank you very much for your answer
Dear sir,
There is option in health setting of UL 3.2.2.enabling of heart rate monitor in skin.
My question is when I enable it, its continuously taking reading of heart rate. If I enable it, may the heart rate sensor damage ? Another may it cosume more battery. Second one what is the use of enabling heart rate monitor in skin?
I am using Finow x7. Thanks
It enables HR only when the skin is visible, so it will not be always active (excepted if you have AOD enabled too). Skin showing HR will be updated live, thatâs the idea.
very very thanks. Its cleared my problem.Now I have enabled it and its giving real time heart rate. I was thinking to ask since very long time ago. Thanks. It is very useful.
Hi
I know this app has evolved over time but i have a LEM 4 Pro and love this app for the watchface functions, but everything is geared up for the Round screens,( Launcher 2 x 2 , widgets etc)
Is there a specific Version that will work best on the Lem 4 Pro ?
