I restarted… is ok now, thank you
Hi Eric. Thanks for the new version launcher.
I installed it on my Prime with screen set to round. For the launcher components to be readable (without zoom or using my cell camera/zoom) I have to Override and set the DPI to 180. This causes some other screens, even launcher screens e.g. Remove a widget confirmation to appear out of the screen. Setting square mode doesn’t help and its still out of the screen. I have to go back to launcher settings and disable DPI override, then go back to remove the widget, go back to launcher settings and reenable DPI override - this does not then auto set the DPI to the value displayed / set previously - I have to click 180 and then it changes to 180 (even though 180 was set on the screen before tapping it again). While DPI is higher than standard scrolling by sliding a finger on the screen is different. You have to slide slower or the screen changes to another screen (e.g. if you are in launcher settings and scrolling down by sliding finger up on screen - you are much more likely to change screen to clock skin by sliding up with DPI on 180 than on 100 or 110, so you have to slide very very slowly)
Some possible ideas to get around firmware guys unwilling to remove your app from square screen setting:
Make your own square screen setting for all other apps that will leave your launcher in round mode but set all else as square
Make it configurable so that square, round, DPI and possibly offset (if there is display misalignment on an app) can be set per application and saved by the user
Hi i cant install UL Clockskin Coc 3.2 because it wont allow me to scroll down on the permissions page so i can tick yes to continue the install. This is on a finow q1 pro/ elife m1. I was able to install the older versions but not the latest 3.2 because of the scrolling issue. This is the first stage where it informs me about the permissions and asks me if i want to update. Cant scroll down to where i click yes etc.I realize it may be a problem with the watch but can you make an installer version that skips thru the authorization permit process and just lets me continue to click the next button? I just realized that the UL clockskin version on my watch is 1.1 But that old version installed no problems
Hi folks,
I have annoying situation on Kospet Prime SE, where I’m randomly getting notifications that the watch is connected to the phone. Somtimes a few times a day, and sometimes a few times in one hour.
In watchdroid, options to notify when connected are turned off.
Can the universal launcher cause this or it’s a problem with watch droid app?
Previously I didn’t have this issue and also, I was on stock launcher, but I’m not sure if it’s relevant, just asking?
The notification comes from the system, look in the system notification settings to correct that.
3.2.2 published : bug fix.
I was also facing the same issue. I have revoked notification access given to UL. My issue has been resolved.
RK
Hi @Eric_Crochemore,
Just now I updated the launcher to 3.2.2 from play store. I have started facing issues with watch faces. I have restarted the watch but it still persists. Please check the video.
RK
Could you try this:
Goto watch Universal launcher settings and deinstall UL. Then goto watchsettings- uninstall aplication. Chose UL. Tap storage. Delete data. Uninstall UL. Then install it again.
Hi @G1NT0N1C,
I did a clean install and the issue has been resolved. There is another issue I have been facing since previous versions and it is in this version as well. The watch-face, in spite of being deleted, keeps on showing the deleted icon. It does not get removed.
RK
Tap a few time more to delete it. I know this problem with a few faces, but it’s not new.
Thanx for the help @G1NT0N1C.
RK
Hi @G1NT0N1C,
The issue got resolved after clean install. However, as soon as I added widgets, the same issue started again.
RK
I can’t confirm. I checked some widgets and everything works fine.
Nice to see that there could be a solution, but I’m not sure what do you mean.
Can you explain pls what exactly did you do?
For which app exactly did you revoke notifications, WatchClockSkin or how do you do it for UL?
Excuse me for possible stupid questions, this is my first contact with Universal Launcher.
I don’t know why I am facing this issue.
RK
I revoked the notifications permission for WatchClockSkin.
Don’t worry about it. Even I have asked plenty of stupid questions. As a fact of the matter, I still do. ![]()
RK
Is somebody else having the same issue ?
I couldn’t reproduce it. Maybe I used the wrong Widgets.
I removed the default Google widgets and added At a glance, Health and Weather.
RK
