Now its perfect,that scrolling bug was very irritating ,thank you for this,can you please check if always time is working,its not working for me,rest all is very good
Always time works well. But if you hit the power button, it will shutdown the screen as expectedâŚ
I have updated the app. Just use the same link as above to download it.
For me after the timeout time,my screen gets off
No i did not⌠that strange. Note that a lot of older watches donât have any calculator included.
I still donât understand the need, if you donât want to use it, just donât swipe to it. It will not change anything if I remove itâŚ
Thanks, I appreciate your cooperation.
Eric,now it works all fine.thks for the bug correction with the update and for your time.
Cheers.
Dear sir, I noticed to day in UL 3.2.1 beta, An icon Hand bright screen on is not communicating with my Finow x7.There is setting named gasture in which a setting for on/off on screen while hand raising. The same setting is on your UL icon named Hand brightness on/off for selection. If your icon selected for off on raising hand means it should never on, upon raising Hand. But if the watch system gesture setting is on for Hand raising screen on, then Afterthat I select from your lancher icon in Off postion for Hand raising, but it is functions like on position. If I select for off it should be in off mode in my sytem setting like volume control. For the working for your Hand bright screen on off icon, I have to go to my watch system setting, Gesture, Hand raising to off postion permanently. No any action found here when changing off or on in your launcher Icon for Hand raising. It should communicate with watch system setting. I hope you will understand what I am saying. Till now I found only this problem.
Itâs not a system feature, itâs a launcher feature. So if you want to use mine, put off the one in the stock launcher.
I installed the latest version (I had to first uninstall the beta otherwise it did not allow me to install), I found 2 bugs:
The first one concerns WiFi, I use to transfer files âesFileExplorerâ because it has the convenient function âsenderâ To transfer files via WiFi, once I plug into the watch in hotspots to the phone, when I press on the âreceiveâ clock, the WiFi is turned off and then the connection ends, forcing me to exit the esFileExplorer screen, go to WiFi and I have to reactivate leaving the screen to receive on esFileExplorer and then send from the phone
The second bug instead concerns the menu, if I go into settings or any other menu, when I go back to the main menu, it no longer scrolls, Iâm forced to go back to the watch screen and then go again in the main menu.
Fixed instead the degrees of the weather (now remains on celsius), great job indeed!
I hope my English is understandable because I use the translator
Some features are basic Android features and can be controlled more or less by apps like my launcher. But some other, are very specific and not standard, so they canât be controlled and are specific to some watch. There was a tome were finow was using a non standard way to check wrist gesture, now itâs more common, but anyway , even if the Android sensor is standard, the.feature is not. Thatâs why my launcher has to implement it, even if the stock launcher has itâŚit canât be sharedâŚ
Hi, @Eric_Crochemore , Everything is working fine , the scroll problem is gone and it also looks good. A small suggestion if you can put setting symbol on notification screen then it will be more convenient. Thanks for your constant effort to improve this app. and considering small and silly suggestions.
I donât get it. This screen is occupied by notifications, where can i put a symbol ?
Well @Eric_Crochemore there are four symbols in upper line and three symbols in lower line , if itâs not getting congested then you can put there. But in the end you are the best judge.
Thanks for taking interest in my suggestion.
The toggles page, yes itâs a good suggestion
Nice job.
All is good for me since one week.
Kospet Optimus pro V3
The latest version has a problem with the widget. They do not work and cannot be deleted.
Smartwatch: Lemfo Lem T
Yes and No, if the watch has a DPI setting issue, the icon will become out of sight and non selectable.
So, after testing (and getting in this issue), i still think that the current proposal is better.
No change on widget. Itâs probably a problem with the install. Try to install again, or just reboot the watch.
