Universal Launcher [Ver. 3.x and above]
In Finow x7 ,after pressing power button a recent cleaning comes, but always have to press the power button. In cleaner widget power button pressing is not necessary. Every time pressing power button may damage the power switch in the watch like smartphone. Anyway It is not a serious matter. Thanks.
Are interactive watch faces possible? Like something that could be implemented.
Where if lets say, we have a paused GIF of a Rose Bud (pre-bloom), we could tap the Rose Bud, and it’ll bloom. But if we tap it again, it’ll reverse and return to a Rose Bud.
Or another example… A picture of a wall with a window, and we tap the window and it opens, and if we tap it again, and it closes.
OR attach a timer to it so it’ll reverse/close after X amount of time.
And to go 1 step further, if this is possible, could we attach an arraytype 100 app to a single gif frame. Lets say… the open window opens to an app attached to the last frame, which if you tap, will open the app, but if you don’t tap within X seconds, it’ll reverse and close the window.
My idea is to have a normal cosmetic watchface, with 4-6 hot spots around the outside, leaving the center open, the first frame of each gif-hotspot will be transparent, so you just see your normal watch face.
But if you touch one of these hotspots, the shortcut/arraytype 100 icon will appear, stick around for a couple seconds, if you press it while it’s opaque, it’ll launch that app, otherwise it’ll vanish.
This way we can have our app multi-circle launchers, without a bunch of icons on our beautiful watch faces.
Use watchmaker skins to do that. No need to develop again all for Clockskin when another format already exists.
Alright, i’ll try that out, thank you. Never used the watchmaker app, i’ll install it on Nox or something and see how it turns out.
I suspect my UL is sometimes crashing, but how do I know for sure ?
What happens is that sometimes when I return from other apps, I get a black screen for some time, and then a frozen watchface appears, and sometimes the message that weather was updated. If I slide away and back to watchface, it works again. No log file in root folder…
The launcher can be terminated by the system when launching other apps, no need for a crash.
Any way of debugging if this is happening ?
Yes, it can be checked if you have a way to reproduce the problem, then give it to me and i’ll look.
Hey Eric, Got a weird problem. So i finally got around to updating from 3.1 to 3.2, since i don’t update my apps frequently… (makes watch hot)
Well, when i swipe down to the quick settings and then Left over to the Universal Launcher settings, the one with Application List Style at the top.
While trying to swipe up to scroll down, it keeps trying to bring up my watch face. Like it’s insanely tough to scroll down through the Universal Launcher settings since it keeps trying to swipe back to my watch face.
I don’t remember having this problem on 3.1 so thought I’d mention it. Thank you.
(Kospet Hope 32+3)
It happens with me too, try scrolling reeealy slow, it works for me then
Yeah that’s how i managed to get through it, but it’s a new problem, so figured i’d mention it.
I have also the same problem but,
if you swipe from the left bottom to the right top to scroll up and visa versa to scroll down.
You can swipe as quick as you can.
neat! diagonal swipe
Not a new problem, it happens on all Android 7.1 since this new setting exists…
I was thinking of putting the setting screen after the app manager, then there will be no problem normally…
I just meant new to me. Some of these swipe things really do seem tricky to fix. I guess it’s not as easy and disabling swiping up to the watchface if you’re on the settings screen. Or for the other problem, swiping up to the widget window or down to the quick settings if you’re in the app drawer.
Beta version of the 3.2.1 for beta testers only :
  • the settings is now in a separate window
  • the app version now appears and is used to show this setting screen
  • health gender corrected
  • location will be automatically set (as soon as GPS and internet are available) if no previous setting is found.
Seems to be working fine for me. Haven’t noticed any new issues with this version.
I also installed it, it works very well, I noticed a small bug, every time you restart the watch (zeblaze thor pro 3g), the temperature is in fahrenheit, although in the settings it is on celsius (just press celsius again to set itself), otherwise it works very well, The menu as it is now is much better and is easier to consult. I set the dpi to 140, perfect in my opinion
Great job, really! Congratulations!
After few days of test,the new coco is fluid,no problems or blocks scrolling in ul settings menu.
confirm me too the bug of temperature when reboot the watch,always shows F instead C,as in Ul settings.
As always, a very good work, Eric, and thanks a lot.
Tested universal launcher 3.2.1 beta version. Everything is OK, but when restarting the watch weather unit changed to Fahrenheit inspite of setting is in Celsius. In version 3.2 ,it doesn’t change. Please look into this. I had tried so many times after fresh uninstall and reinstall.
Now I am on 3.2 . Uninstalled 3.2.1 beta.
