This is the LEM 12 pro you are using?
If it is, I will make a special thread later on and you will be able to let me know how things are after I make this post.
So keep an eye on the LEM 12 pro section.
Cheers.
Pablo11.
Thank youuu, i plan to really get down & dirty & use this watch for its full potential. I tried to set a widget for Google maps on universal launcher & i couldnāt
any help?
I would suggest downloading messages by Google i think it works really well Instead of the stock messaging app
@Jonathan_Bickel the swiping down then 2 the left worked by touching the watch looking icon, Thanks 4 that
Is there a way to turn the background in the notifications off ? As I sometimes find it difficult reading messages over the existing backgrounds.
Select high contrast notifications from the pull down menu. Next to the ringer volume control
it is possible to use UNIVERSAL LAUNCHER to TicWris Max.
Yes, thatās possible.
You can even install it on your Android mobile phone and play with it
Itās Universal
That I have done itās fun to play with. The touch points donāt always work correctly but it was fun to play with for a while
How do you have contacts onto the phone? The stock phone app is terrible & i cannot reach the save contact button on the add contacts page. Regards.
BT sync is probably the best way.
Try this phone app instead of the stock one.
https://drive.google.com/file/d/1_WaBosRONDWv0J5OKl16RTPf7sPF7mtM/view?usp=drivesdk
I use Google contacts you should be able to find it in the app store. It will help save and sync contacts across all devices
Thank you. Though i need it just for the watch. Iāll try regardless. As long as i can save a number that has called me into contacts thatās all. Thank you
I have them both installed on my watch. As well as Google messenger. I find them much easier to use then the stock apps. On all my watch faces I make that have phone touch points use the true contacts dialer pad if you are constantly calling the same people it works nice plus is cool too get the picture ID in the background when the call is coming in. Makes it easy to see is calling on the watch.
2 posts were merged into an existing topic: LEM12 Pro A10 Official Support
These days whenever i unlock the watch it always asks me to choose which launcher to do so with. Is there a way around this? I think i may have selected an app to sleep in the battery optimization section but watchclock seems to be on. Unless Iāve done something else
Itās the same as a phone.
Go to Settings, Apps, Default apps and select the home app that you want to useā¦
Goto settings- apps- special app access. Disable āwatchclockskinā from battery saver.
This was done ages ago & it still asks regularly hence the question. Thanks anyways
Thank you for this. It seems Iāve discovered a new section of the settings. I tinkered around & even though watchclock skin was already not optimised for the battery saver. I went back to optimisation & flicked the switch on -off & thereās improvement. Thank you
