Download it to your PC, unpack it and push it via USB to your watch. If you don’t have a PC, there are other options. In this case, let me know.
I don’t have a pc. Please show me the other options. I have my smartphone & the watch
I’ve recently started using the normal alerts instead of high contrast and really like them now. When I first started using normal alerts the random colors were kind of weird so I switched to high contrast. But it wasn’t till I got a text message or anything with a profile picture in it. The alert comes up as the person’s profile picture and that’s awesome… the only issue I have is sometimes they are pretty clear others are super low resolution and can’t see well. I assume it has to do with how well your service is but if anything could be done about it that would be great.
- List item
It also took like a month to figure out why the weather updates weren’t working, I’ll make a youtube video on what I ended up having to do
If possible adding the ability to use the gyroscope and 3d features of the .Watch format would be a cool bonus.
I’ve got some .Watch format stuff that won’t work properly and would be fun to have on the Android watches
Just download the face and move it to the clockskin directory.
Gyroscope is already supported. For 3D, I have not looked yet, if you know some sample faces, I can look.
It depends on the icon resolution sent by the program. For weather, if your gps has been set to fine one time, it’s enough to get your location. Then only internet access is needed to update.
i can upload and send you some files, i have one with a 3d image that should twist back and forth with wrist movement and it doesn’t seem to even load that portion of the watch face. i tried a sample one with just a floating rectangle (no 3d image) and it also doesn’t rotate with the wrist.
Send me the links in pm. Thanks
Hello Eric!
First of all - thank you very much! Amazing job!
Here is some feedback from me on Universal Launcher 3.2.2 from Google Play Store on Lemfo LEM12/Oukitel z32 Android 7.1.1 400x400 round screen (I know, some of this has already been mentioned):
- Upon returning from any app with the back hardware key to the App list, the App list does not scroll anymore. Trying to scroll will either bring you to the widget area (scroll down) or to the control center (scroll up). Just like if you were on the Watch screen, not in the app list. To make it unstuck you have to swipe left/right to trigger an update. Hope it is an easy fix;
- The icons in the App list (matrix mode) are blurry. Like when you scale something with a factor of 1.25x or 1.5x. I think this problem should have a solution under Android, all launchers that I tried on a bigger phone scale (or just use the correct icon resource file or something) those app icons correctly. Not a deal breaker but not eye-candy either. Hope it is an easy fix;
- I know, this one you’ve heard many times. Making the round screen go in square mode makes Universal Launcher go into the square mode too. Hope it should be fixable and the Launcher could behave as any other “native” Lemfo app that just ignores this square mode setting (Browser, Calendar, Phone dialer, Native Launcher etc);
- Notifications sometimes stop coming to the Notification panel. Vibrations and sounds come through as a notification arrives but no message in the notification panel. It is just black and says No notification. Restart the device helps. This one is critical for me but sorry for the non-concrete bug report, I will try to investigate what triggers this behavior;
- A minor one, hope an easy fix too: the watch face is frozen right after Reboot. You would have to trigger it by swiping in and out of the watch face to make it start updating;
- A style preference: I think would be nice if the Open/Dismiss buttons in the Notification panel will have no background and border. Just text telling Open/Dismiss. It will make the GUI look cleaner.
Overall - great job! I’m very impressed. The Full Screen Widgets feature under the watch face is amazing. I have my calendar agenda and the shopping list in there. Very cool.
Maybe you should collaborate with the watch makers to sell your launcher together with the watch natively.
Thank you very much!
Hello. Ok yes I did that. Was going to complain that there wasn’t an option to paste into the clockskin folder but i just downloaded a new file manager instead. From there, after extracting. I seem to have the 2 new moonglow faces but on square watch face it’s in the middle & not stretched out to the full length of the watch screen. & On circular watch face it’s even worse. It goes to the corner of the actual watch at the bottom left. Any way around this? Regards.
Yup, also suffering from these problems & i have three latest 3.4.8 version. Good app but a decent amount of bugs. Needs more polishing respectfully. The colourful background when there’s a notification is very unnecessary. True that. Regardless i appreciate your work.
Just a few things i feel should really be changed in universal launcher.
1- despite the main watchface. On every page it should display the time. Nothing fancy. Just a small digital time so i know what the it is without having to go back to the watch face. Like how my smartphone states it’s 09:46 in the top right corner. Very useful & the should be one at the top middle at all times on every page.
just put it in round mode and then restart UL
2- the orange timer that comes with the UL just before the calculator is too much! When using my actual mechanical watch in the gym. There’s a button you press that starts a timer that goes up to 30 mins. That’s all you actually need. Literally just 2 buttons. One for starting the time & another for ending then, when pressed again. Restarting the time to 0. The amount of numbers you have that lets you set a custom time is way too complicated & because there’s so many numbers touching one seems to mess with the others more time & it only causes frustration. In the end. While I’m trying to get a rest period in at the gym before my next set too much time is being wasted. Thank you.
I’ve done that several times & the watch face is still not fully scaled to the full LCD watch. Any way around this?
If you double click the watchface you can choose to scale it up or down
You can change the color of the timer or calculator by tapping on them.
If you want a easier to use timer feature you can find some faces in .Watch format and they can run timers directly from the watch face
Try this watch face
I have & when i do after 6percent scaling there’s imaginary borders the watch face goes past so there’s a massive black space. Hence why I’m asking if there’s a way around this
