No, DPI is default at 160!
So put it to 180 in the UL DPI settings
I will try and let you know!
bluetooth is stable and does not cut out with standard launcherâŚas soon as i put UL on my watch the bluetooth connection between watch and phone flickers on and off all the timeâŚwhen going back to stock, it stopsâŚdont know why but it doesâŚ
no, changing DPI only makes font bigger or smaller, longer messages are still not completely displayed, only 2 - 3 lines are shown? on stock launcher complete notification is shown, no matter how long!
Oh, interesting. I was wrong then!
I suggest that you remove the pairing profile from the both phone and watch and start fresh.
What phone are you pairing to?
Which Android version is it running?
Which watch are you using?
Kospet Prime 2
@Nspz_73 Ok thanks.
Interesting how it is negotiating the image using angles instead of curves. I actually prefer it, but thatâs not the point
Have you tried it on any other Android watch?
I am very curious about this.
phone is galaxy z fold 2 running android 10âŚwatch is kospet prime 2 also on android 10âŚwill try it later in the day by removing the pair and repairing
Interesting⌠Thanks
In fact, I have to exaggerate the radius in WM to achieve the look I want.
And it takes several tries to get it almost right.
Make sure watch Droid has battery optimizing turned off and un restricted data is on if that doesnât work I would delete and re pair the watch and phone Bluetooth connection on watch droid.
This link doesnât work.
Here is the 3.4.6, it should work ok.
By the way, this is a really nice face.
I fogot to say that watchmaker âprogressâ layer is also working on 3.4.5
The face is not a personal creation but a mod to adapt it to my uses on the Kospets.
Progress, yes I had recent lssues with thatâŚ
Will test itâŚ
BTW, I also have issues with âCircular textâ, I donât remember the exact name.
When I want a text to fit around a watchface, I canât use the WM tool for that.
It works on UL but not consistently.
If I reload the face the curved text works on the âpageâ I am.
But if I have a curved text on another âpageâ of the watchface if I switch to it, the text wonât show.
Itâs a weird behavior, so instead I use regular text, rotated word by word.
Not perfect but itâs the only workaround I found.
I will try 3.4.6. Thanks.
Rounded rectangles seem to be fixed!
Thanks.
