i already answered. if you want logs, you can use the usual android debug with USB
@Eric_Crochemore hi Eric how are you. I have a Prime SE and yesterday i installed UL, it was excelent untill today that mine watch batery went o% and when i recharged the UL freezz and min clock skins desapear
any ideia ?
Are you able to access the watches menu ?
Not really, a reboot should fix it.
Yes i can enter the menu, sometimes also freez. but no clockskins, when i try to change skin freez and dont change. Is there a instalation video for UL ?
Then when uninstal UL the skins are there.
Tx
I reboot several times uninstal reeinstal and no good.
It work weel till drain batery. After recharge dont work.
tx
Are you talking about the stock clockskins that come with the watch ? If so you will never see these when using UL . Just faces you have installed
Talking about the UL skins iāve installed ?
Goto round mode and restart the watch.
My weather forecast is broken somehow. It displays thunder, thunder-rain icon in clockskin face, and cloudy-day icon in watchmaker face, but both of all doesnāt look right. It does not match with any weather sites status(Guessing temperature also wrong.). My watch is āLEMFO LES2ā. Cellular data, GPS are working and checked main location setting is valid.
So in UL settings you have location correct ? Its normall set at Paris by default. UL uses Yahoo for its weather . Connect to wifi and it should work .
wifi doesnāt help at all. And location is correct. I have double checked. Also as I wrote, clockskin face and watchmaker face showing totally different weather condition. It makes no sense even if location is incorrect. It should display for same place on the earth somewhere I guess.
Hello Eric and everybody.
Iām going to install Universal Launcher 3.1 but I would like to ask as I read that supports watch files and wear OS watch faces (that I donāt know if are the same thing) if I use Universal Launcher 3.1, will it support normal zip watch faces from stock launcher of Kospet Prime?
Sorry for this Noob question.
Iām trying Universal Launcher 3 and I see only 1 watch faces zip I had installed and it has a small size (not fit screen),. How can I see more watch faces? I try pressing that watch face but it doesnāt show more and how can I make that watch face fit the screen?
Sorry for these noobs questions.
Thanks in advance for your help, support, time and launcher development.
As G1N said a few posts above:
@noidremained Thanks!!
I recently bought LEM12 and tried to install UL 3.4. It worked generally fine. However, once I chose āroundā application list style, āSettingsā icon in Appsā list never respond to my touch. Access to āSettingsā from āsliding down, to left, to left (from watch face)ā still works fine. Even if I chose back to āmatrixā application list, āSettingsā icon does not respond in the application list. Whatās wrong?
Itās just that the settings window is already running in background and the system doesnāt want to show it. Maybe thereās something I can doā¦
You simply need to install new faces in the clockskin directory to see them in UL.
