@Eric_Crochemore Thanks a lot!! They are working perfectly.
Regards
Regards
Thank you very much for your comments. I understood what may have been going on. It is not very serious but slightly inconvenientā¦
For the nice clockskin change without PC video
I donāt understand the reboot, it takes very long time, why is this done ?
Instead you can just open the watchface select, go all to the right and press the update circle.
Is there any reason for doing it with the reboot instead of the skin refresh ?
To be honest its just a precaution only . Glad you liked the video
if the SIM card is not inserted, Wi-Fi may not help. For example, I have a time shows +5 hours to my
Sorry but i have no idea what you are talking about
R/Sir,
This is a request / suggestion for universal launcher.If whenever you upgrade your universal launcher in future, please try to remember to look the problem with marker ( Dash marker, dot marker) which is not working in .watch face while zooming. Where as Digit marker imported by WM app. is working normally. No problem with digit marker.
This is for your kind suggestion.
I am still using your UL .If needed with any watch face, I use to replace the marker with .png image. Never thought about zip face.
Thanks with regard.
Hello everybody.
Someone can help me.
I have a Prime and I want fix the dial square/round mode
I see Somewhere in a thread something about the modification of xml file but i canāt find it anymore.
Not clear what your problem is.
Hello.
When iām in square mode and i go back to the watchface, the face is not in full round mode and i have to reboot the watch to solve this.
Like this:
Iāve Seen Long Time ago Somewhere an answer but i canāt remenber.
The solution was to mod the .xml but iām not sur of that.
Thereās nothing you can do about that. Maybe if you have root access thereās a system file you can tweak but I donāt know which one.
Ok.
I have root acces.
Thanks you.
Hi @Eric_Crochemore how are you ? Can i install direct the latest version of clockskin or should i go step by step ? Tx
No need for step by step installation.
Tx. Because when i open the app it asks if i want update a app already instaled. Anyway thank you.
Congratulations on your launcher. Hope to see updates soon.
@Eric_Crochemore. Hi Eric hope u r well. Iāve just treated myself 2 a Kospet Prime. I was wandering is the 3.4 Beta ur latest version or do u have a more updated 1 available?
No, 3.4 is the latest.
@G1NT0N1C. Thanks 4 ur reply. The Beta one?
