Jan 31, 2019 12:13:05 GMTozze559 said: hi. I need some help please. Im not a newb to the android hacking scene..but I need help with a issue.. Please provide the sp flash tool you have used.. SO..i Powered off my device completely. I download sp flash tool. I loaded MT6739_Android_scatter.txt on the sp flash tool..ONLY two files are checked on the app..one is for recovery and the other is for boot..now I press download and connect the charge cable on my powered off lemx..and NOTHING happens?? I do have usb debugging enabled and I enter adb devices..and it shows up..What am I missing?? any help will be greatly appreciated and thank you guys
Please install the MTK VCOM drivers.
Easy to find the latest version on the Web and the installation videos.
This is your problem and it will be fine after this.
Thank you so much for the help really appreciate itâŚi will do that asap!! last question?? do I need usb debugging on or off?? it doesnât mention it at all on the tutorial? thanks again
Feb 6, 2019 13:07:29 GMTmarkap said: I hav tried this procedure on Lemfo LEM8 but the SP Tool tell me that the "Scatter File is invalid". Have you any resolution? Thanks
Try moving everything to a folder with a short path name and without any spaces in the path, like C:/Mediatek/whatever
Thereâs already a built-from-source twrp for the LEM8, you can find it on this forum, but I donât know the specific thread right nowâŚ
I posted it temporarily in the lem8 section in a thread that this member was using.
I think the built from source version is much better and when I saw ports being posted I had to post your build.
I think there was some frustration that it was not posted âofficiallyâ
So I was busy and just posted it there.
Sorry iscle
Feb 28, 2019 9:51:57 GMTiscle said: There's already a built-from-source twrp for the LEM8, you can find it on this forum, but I don't know the specific thread right now...
I think there was some frustration that it was not posted "officially"
Sorry iscle Oh, hahaha don't worry! It's okay that it was not posted officially, as we didn't create all the packages for it, etc... We can post an official version when we finish everything we're doing so that we can also create the TWRP_patcher.zip and all those packages that are necessary...
I followed these instructions to the letter. Everything went as was explained but when I powered my LEMX back up to finish the root process, nothing happened, black screen. Watch does not seem to power on or boot up. The watch is just a really fancy paperweight now.
I have tried running the root process again, but being the watch will not power and boot up to interface through USB, nothing happens, I get error messages.
Is there a way to boot the watch back to the factory installation? Can someone please help? I just wanted to Root,Magisk, and unlock my IMEI in order to use my sim card in the watch.
Would it be possible for someone to give me instructions on rooting my LEMX and installing Magisk? Or walk me through the process? Iâve followed the instructions posted on the forum here, but when I do that, the watch boots and screen is scrambled and unreadable and I have to flash back to factory settings, I think Iâm doing something wrong.
I just got my LEMX and tried to flash the referenced TWRP; since this post is a bit old and Iâve updated my LEMX to the latest OTA, I figured I better flash just the recovery, so I deselected boot in SPFT and upon reboot I got the âNo command.â. Then I proceeded to flash everything (so recovery+boot) and ended up w/ a black screen. It seems that the watch did boot into recovery, but nothing was displayed - I could get adb â0123456789ABCDEF recoveryâ. Aftewards I flashed the 20181217 firmware and upgraded it again, so my LEMX is operational again.
So, what am I doing wrong? Is there a need for an updated TWRP+boot?
Thanks in advance. Regards!
EDIT: I tried it the 2nd time and it worked⌠oh well. tnx
So I followed the steps here to get twrp installed-- which it did install. But when i boot to twrp this is my recovery screen (see attached link for twrp photos)
And whats odd about it aside from the photos, is when its booted into the OS-- none of that glitching happens. Can someone help please?
Had to use a renamed Google Drive link since apparently im not allowed to embed photos or use links for that matter.
