put the gps on and in high precision mode,wifi on,wait until system found gps,touch more time … until you see gps found and your city name.
sometimes it want time to find gps position.
bye
Location permission for Watchclockskin is on, location is in high accuracy mode. Went to outside to have better GPS connect, located me in Google Maps but anyway main location: Paris is not editable.
I saw that user Irohunk had same problem with Kospet Prime watch. Did he resolve the problem or this is problem with Kospet Prime?
Well, It works on my Prime and my Prime SE. I’m absolutly sure that you’ve skipped a permission.
Maybe t ry to update the firmware?it’s new?maybe solve it
Unrestricted data access was not switched on and it resolves issue with Main Location. Thank you.
However, it did not resolve problem with temperature icon on watch face. It is still 0.
And Health widget’s step count is not moving on, nevertheless step count on watch face shows step count growing.
You have to enable heartrate monitor in launcher settings. Make sure that you enabled Universal launcher in Battery saver.
Yes, those were done. Heart rate check works perfectly.
Fixed a calories and distance bug in Touch Multicirles Translator version and update the file.
thks
Make sure the system setting for steps is turned on.
My watch today morning in UL mode:
Step count on watchface 914, on health widget 0.
Temperature+1.
In Android mode: step count 914, on widget also 914. Temperature +3, that is correct.
It seems that UL widget cannot get info on step count from the watch as well as temperature for the watchface.
I have given all possible permissions in UL mode.
Actually, it seems to me that UL setup is very complicated for a common user. It requires to dig deeply into all possible setup menus. Would be better if default installation includes all necessary permissions ON and with a possibility to switch them OFF when necessary.
Make sure the system setting for steps is turned on. And make sure that watchclockskin is disabled in battery saver: Goto watchsettings, more, backround Cleaner, tap on Battery saver. Disable watchclockskin.
Yes, the first Setup mayme a little more complicated then stocklauncher. But if it’s done, you can use a lot of cool features.
Dear Moderator, I had purchased a Finow x7 about 2 month ago. From the beginning It screen has a fine red dot glowing just below the 1 number of dial. It is normally not visible but it is seen when seen deeply.
Here I want to know from you that is it a screen burnt or something else ? It has Smoled screen
I think it’s a screen issue. But this is not the right section for this question.
Thanks, I know this not the right place to ask this type of questions. In reality I do not know how to post the question and where to post.
Go to categoties- finow products- FinowX7 and open a new topic.
I have loaded updated file to my watch but I cannot see it in UL mode. It is nicely seen in factory settings mode and works correctly. However if I click to Watchclockskin (UL) mode, it was disappeared.
Disabling watchclockskin in battery saver did the job. Thank you.
But now Malex nice watch skin was disappeared in UL mode after fixing bugs.
You are welcome.
delete my face zip or folder in your clockskin folder and copy it again.try
