welcome to the most famous watch thread of the year.
Yeah, done. Clock skin is back again! Step count figure is now corresponding to one in Health widget app.Only one question remained. Wherefrom clock skin temperature figure takes info in UL mode?
It shows me 0. However, weather widget shows +5, that is correct. In factory setting mode (Android mode) it shows +5 and always updates after Weather widget starts. In UL mode, not. Is there again some permissions that must be enabled or disabled?
Sorry,I did not want it.
As always, you should set the location in your watch ul setting. Watch the video tutorial.
OK. It works. Does it mean that every time I want to see correct temperature count on clock skin I must reset location?
Even if I did not change my location? Isn’t it possible to obtain correct count from weather widget while starting it?
Today morning I saw incredible step count on my clock face 31,750 and 22,4 km. It seems that somebody was walking with my watch all the night. However it was on the charging cradle. Health app showed 0 that is correct. I reloaded clock skin, restarted UL - no help. Then I found out option in the UL settings - reset step count. If I reset step count and thereafter restarted UL, step count on clock skin turned to 0 but on Health app it was 320 (real step count in the morning).
In factory setting mode all is correct. It seems that your clock skin does not interact correctly with device sensors or widgets in UL mode.
You don’t have to reset, but just SET it only one time.
Yes it’s a bug that can happen, i still don’t have found the reason yet. Anyway, you have to understand that step counter is not a “per day” counter, so it keeps incrementing day after days, it’s up to the application to show you a step count of the day… That’s why you can see different numbers.
Would it be possible to have a touch “circle” hot spot as a gif, and have it cycle through different apps, and you just wait for it to get to the app you want?
Like, assign a different app for each frame? So instead of 6 hotspots, we could have 2 hotspots that cycle through 3 different apps each, staying on each app frame for maybe 2 seconds.
Is it any way to display the network signal directly on watch face?
No, that’s not possible.
Thanks for reply.
