The array 62 line has to be added twice ( not three times ) to stop the .gif file from flickering ( no-one knows why ) . The framerate line is added by wfd when you add the .gif file ? You dont need to touch this . As i said , complete your watchface in wfd with .gif file etc and save it as a completed face . Once saved go into file and add TWO lines only . Thats it
. Its magic
Arraytype 62 looks pretty cool too, but i like universal launcher, except that 1 bug that eric and everyone else canāt figure out.
The one where if you close the app and it goes to your app drawer and you try scrolling up or down it goes to your widgets or to your quick controls.
So you have to go to your watch face first then back to your app drawer.
I love your watch face.It is very informative and clearly readable. Is it possible to add screen brightness slider? In some reason position number 9 (offline maps) does not work.
offline maps,for works,you have to install it froma paly store,because itās not part of watch firmware.
Do you want the screen brigthness instead offline maps?
Thanks for advise. Offline maps are cool option. I have downloaded it and will use. Could you put screen brightness under temperature or change weather under temperature icon and screen brightness under sun/moon icon.Is it possible that temperature and heart rate is checked and displayed automatically once in an hour or when screen is activated for example?
Iāve update the tranlator version with brightness screen level.
Temperature and heart data depend form the system apps,so canāt give scheduled command.
maybe with tasker or macrodroid app you can do it.
bye
Great watch skin now! Thanks.
I dare to present a wish to make this watch face perfect to me. Add round calculator to some empty place - minutes for example.
thereās no more space in this face for another icon.for me,the best,is that you install round calculator and add a widget with it,scrolling down.thks
The app is included in my launcherā¦
right Eric.
How do I see it?
How to add a widget to Kospet watch face? I am new on it. Just fresh Kospet prime watch ownerā¦
you have to instal universal launcher,if you havenāt,then in ul,when you are in the main watch face,swipe up and you are in the widget windows,and you can add all the widget you want.
https://www.youtube.com/watch?v=qbgxI8lH86E
https://discourse.fullandroidwatch.com/t/universal-launcher-ver-3-x-and-above/53131?u=malex
bye
Thanks, caught it. Installed universal launcher, added widgets. However, yourās nice watch skin does not work properly with universal launcher. Temperature, pedometer, calories, distance windows show wrong numbers. Other buttons work correctly.
Sorry! Rebooting launcher corrected pedometer.
Testing Universal Launcher on my Kospet Prime.
Step count works now on watch face after relaunch, however step count does not work with Health widget. Relaunch corrects it but thereafter freezes again. Also temperature reading on watchface shows all the time 0, however weather app shows +2.
As always, you need to set the location in UL. Look the YT channel tutorial
I watched tutorial once more. I am unable to edit main location. This is set as Paris. I am able to edit other locations. Watch is Kospet Prime. Steps count seems to work now but temperature is still 0 and does not update with weather app.
Make sure that UL has the permission to use GPS.
