Touch Multicircles
How it is touchable ? touch not working with stock launcher in finow x7 watch. Please reply how the touch icon will be working.
If you touch the icons it opens the app / feature . Works mostly on android 7.1.1 watches . If the face has a touch section for the app . You must also have the app installed . Ie whatsapp etc
i have not installed whatapps, but I tried for dialer,alarm etc that you had mentioned in your details. But nothing works as a touch interaction.
What watch are you using . Is it android 5.1 or 7.1.1.
Finow x7 ,Android 7.1.1
Try this face and let me know if the dialer works on your watch . Not used a finow for years but i do know of previous compatibility problems ( not new though )
hi,maybe the cls and pkg of the dialer in Finow are not the same in Prime,I don’t know.
you should see with Package app in your what cls and pkg you have.
bye
Downloaded it, it is of 8.28mb. Installed but it is also not working. In its display the smoking monkey is also not visible. Only the icons and time seen. No any icons are touchable (interactive)
I am using stock launcher built in watch. I am not using Universal Launcher.
Then its a issue as mentioned above with Finow . We tested this kind of thing on many watches and works fine . As mentioned maybe the faces can be tweaked to work with your watch ?
Yes face can be tweaked to seen in watch face. But I am interested in touch active so that dialer can be opened from the watch face screen by touching the icon. Any way many many thanks for taking interest in my problem and giving your valuable time. Thanks
My watch is not rooted so I am unable to see the actual package name in system file.
You do not need root . Use this app on your watch ( not phone )
Maybe his watch is android 5.1?
He said 100% 7.1.1 ?
Maybe he’s wrong but seemed sure
Jep, I just read it. My mistake.
Is it an app? I think it is a watch face zip file. Which I had already installed and gave a reply to you that its touch function not working.
My mistake . Post edited . Yes it is a app
Thanks, I will see now.
Just now I have checked the package name in clock xml file after installing the apps in my watch. Every thing you have written is same in my watch package name. Nothing different. Nothing found wrong. Did not find why the touch is not working on clock display. Thanks for getting knowledge from you.
Did you try with ul? Maybe the stock launcher doesn’t support arraytype 100
