Oh yeah… But not a bad idea to try again.
Personally, I would check that the screen is connected properly. But I’m afraid it’s a broken screen.
And if you do open it up and check after reset be very carefull . Connector is very fragile
You seem to have had some experience with this connector, Doctor…
Mmmm
just a litte
I know if I opened it up, I would screw it up more than it is already.
Anyone know how to reduce very loud volume of opening and closing jingle music on kospet prime 4g or to switch it off completely?
Not got an answer for you, but I’ve got the hope and damn that things noisy
Hope someone has an answer I would be all over that in a flash.
@Mark_Williams
Please return the watch.
If you haven’t made arrangements already please contact Kospet at
after-sales@kospet.com
Give them all the details of your purchase and get a replacement.
ok, cool. In your experience, is this going to be a hassle?
Put notifications into “silent” mode before powering off. This will completely turn off the sound on powering down and when you turn it back on. Just remember to return to “normal” mode after turn the watch back on again.
No. If you have any problems send me a message
See my reply to wmchikwanha.
Has anyone found the link for twrp root of Kospet Prime? Every lead is a dead end.
It’s in the firmware pack
In this pack.
Pull it out with 7zip.
Patched boot is in there as well
Thank you Pablo,
I flash it with adb. I get this warning:-(
FAILED (remote: not allowed in locked state)
PS C:\User…\KOSPET_PRIME_v1.5_B_20191106\image> fastboot flash recovery recovery_TWRP_Prime.img
target reported max download size of 134217728 bytes
sending ‘recovery’ (13510 KB)…
OKAY [ 4.038s]
writing ‘recovery’…
finished. total time: 4.063s
Did you enable USB debugging in watch settings?
Its much easier to take the scatter file and the two images and flash with SP flash tool
I used flash tool instead of adb. I renamed recovery_TWRP_Prime.img as recovery.img and used the existing MT6739_Android_scatter.txt to flash. I chose from the entire list only the renamed recovery.img and boot files to download . Then it worked. Twrp is installed. Then I used the fast boot adb to start in Twrp recovery, installed the magisk_patched.img, it is rooted!! Thank you again, Pablo.
Glad to help
