Yes, the action is called ‘System optimization’ on apps.
@tuiter is there an app for quickreply on lockscreen…just as phone and numeric badges for example whatsapp?
I don’t think it is possible because the notification system is custom. Not quite like a regular mobile phone…
But you never know.?
Pablo is right. I don’t know what kind of customized notifications you have, but you can try https://apkpure.com/heads-up-notifications/codes.simen.l50notifications/download/64-APK?from=versions%2Fversion. Good luck!
@pablo11 But returning to the possibility of wake and shut the screen without use the gesture way or the button !?!?!? Is there a app for doing that by taping on the screen ? Tx
There are some apps, you’ll find them on the playstore. But they will eat your battery. Why not using wrist gesture? It will need some battery, too, but not so hard…
I share a method that does not require frequent use of PRIME’s “power-button”,we can use a build-in function ( raise hand to screen on) & download an app ( swiftly-switch-pro),maybe it will waste a little battery power, but this method can protect our PRIME’s button for a long time!
wrist gesture, it´s not that precise. It goes on several times, even if i don’t meant to. Anyway tx a lot.
i see the plus in use the app along the wrist movement. but my problem is not on turn off and on the watch, but simply wake up the screen without use the mecanich button. Now thanks 2 you guys @G1NT0N1C and @Rogerlo0929 i know tht its possible and how to do. Once again many thanks
It seems no browsers on the Kospet Prime can access the Internet when using Cellular data. I turn off airplane mode and the turn on mobile data but no Internet access via the Browser. I’ve looked through nearly every setting and tried many things but browsers only access the Internet when Wifi is on. Never had this problem on other watches. What am I missing? I’ve tried the default browser, Foss browser and Lightning browser. Nothing functions with cellular data on except cell phone calls and cellular messaging. SIM I’m using works fine with browsers in other phones on cell data.
At this point I’m just guessing that the data bands on this watch don’t match anything available here?
@droidtrix Well you must be missing something like the Background Cleaner setting or data restrictions setting.
These are found in the watch Settings/More/
Because it works fine normally.
Have you enabled cellular data in Settings/Connect?
Hi pablo11, I thought I had looked through everything but I’ll dig around again. Cell data was on in Connect. Even tried turning on roaming. Turned on performance mode. Tried 4G preferred, 3G preferred etc. I’m sort of out in the boonies here so it’s possible the Prime doesn’t have a data band that matches up with anything available here but hoping I am just missing a setting somewhere. Looking again now…
Just noticed now that on the battery page above the main watch page that ‘3G’ shows as being active but when I click on weather it says to insert SIM or use mobile data and browser still says no Internet unless Wifi is on. still looking …
Also turned on Performace mode, turned off data saver, turned on browser setting to allow it to always access data. I think I’ve looked at almost everything. Still on v1.5b. I doubt that is a problem though. Even turned on ‘aggressive wifi to cellular handoff’ and cellular data always on in Developer options but still no internet access with cellular.
Do Internet-based applications work? weather, voice search, google assistant, play store?
No, none of those work unless I have Wifi turned on. Also checked in “Special Access” section to allow browser to have “Unrestricted data access” in trying to resolve this.
Silly question . Have you actually got a 3g signal ? When you insert a sim in these watches you have to reboot watch . Dont expect a signal indoors as strong as your phone.
Yes that is switched on. It seems odd that 3G is lit up whether the cell data is turned on or off.
It appears I have 3G and I’ve rebooted may times since putting in the SIM 2 days ago. pictures in a minute…
BTW thanks everyone for jumping in to help here.
Any signal bars lit up ?
