What solution I forgot my password for the hour kospet Prime
@Abdulrahman_Harbi Welcome to the forum.
As you have forgotten the password and did not set a photo to unlock (I presume) you have little option apart from flashing the firmware.
This is the way the security works and is intentional.
If there was a way around it - it would be fairly pointless having it.
The firmware is here https://drive.google.com/file/d/1nFw1fbl6N_v_VLSuJkVUPHvxmQjspSkw/view?usp=sharing and once you have flashed it you can take the OTA to get the firmware up to date.
Important - make sure you understand the process before you do this. There are many good tutorials on the web and we also have them on our YT channel:
Install drivers first - how to video https://www.youtube.com/watch?v=Xmq6ENu1dcI&t=48s
Then flash - how to video https://www.youtube.com/watch?v=wVn4UhHIFdQ&t=1s
After flashing make a full factory reset of the watch to make sure everything is clean.
Alternatively you can wait until I post the latest version (1.5) in an hour or two. Inside the package I have included TWRP recovery and a patched boot image as a choice for those needing root access.
yes i have granted the permissions needed to display on top of other apps
@floon
You will need to work through the restrictions and permissions until you find the problem.
Background cleaner and others in the advanced settings etc …
I look for the solution in all the parameters of the watch, all the permission and all economy mode ect I do not find where the problem comes from, that’s why I demende help
there is a problem . ( all application floating ) no stay permanently when I put the time dial, the application disappears
All I can say is keep looking - I don’t have the answer for you
Sorry mate.
np thanks for help . mate ,
I hope someone installs and finds the solution for this application (floating toucher premium) and the best App for smartwatch !!! https://www.youtube.com/watch?v=yqDUKkr8WKk&list=PLlcMt_sdtxsBQgA-iq9xHXjXzguQ5kW_i&index=37&t=1s
Awesome!!!
Hi friends,
one question to battery life.
Does somebody knows it
- no wifi active
- no bt active
- no gps active
- only SIM inserted and active
Any experience
Thanks a lot
Regards
Based on what you have said you will easily get two long days with this . The battery is awesome on this watch
Hi friends,
does the prima supports “always on” display
The Kospet Prime has an IPS screen not Amoled. Always on screen mode is for Amoled because of the lower power draw and low risk of burn-in.
I know that some may say that you can use various options to make your screen stay on but it will
a) chew up your battery life.
b) reduce the life of the screen
c) you can very easily find elements of a watch face will become semi permanent on the screen - burnt into the screen.
So short answer is no.
Long answer is as above…
Zeblaze has released a watch with always on screen and it is not amoled.
I believe that there will be problems with that model in the long term.
I’m newbie here, but why “screen on” if screen on rising is working pretty well?
You’re right. Especially since “always on” only works permanently on OLED screens.
Is there some trick to get the Arc app list into alphabetical order?
Amoled suffer of Burnbin issues, not IPS/ LCD and the organic composition of the Amoled has a less life span than IPS/TFT/LCD. In Amoled the Blue leds are the one that starts deteriorating first. Samsung with their amoleds displays use pixel shifting to avoid burn In, I don’t think it’s applied on Smartwatches
Ok cool.
But we have seen it happen to the LEM T for example.
It’s fair to say that you are taking a risk by trying to keep the IPS screens on all the time.
There has been no evidence of burn in issues on the amoled screens over the last few years.
But I’m obviously misinformed…
I was misinformed too
