I am new here and encountered intermittent speaker problem with my Kospet Prime watch.
At times the sound coming out is so soft even with maximum volume setting that is hardly audible. Reboot don’t help.
When I leave the watch idle for sometime, the problem may just go away the next time I use the speaker. This happen several times over the day .it’s frustrating
And I can’t rely on it to make or receive call.
I encountered this prob a few days ago.
If you are on the latest firmware and have reset watch afterwards there are only two things you can do
Return watch
Open up watch ( you will have no warranty if you do so ) and see if anything is restricting the speaker . ie waterproofing tap
But is it just a security issue?
I can install Gpay and cards!
If supports should be active as there is more utility beyond payments. Domotics for example.
Hope it will be accessible soon, it would be excellent.
Does the rear cover of your watch have a little tiny hole in it?
A lot of the speaker problems are due to high vacuum pressure used when they seal the watch and also the excessive amount of sealant they use to try to keep the water out.
So they started using a tiny one way pressure relief valve on the rear cover.
Some advice - if you are going to remove the rear cover - be very careful because it is a very tight fit!!
There have been quite a few cases where people cannot charge or use data transfer after removing the cover. Due to the design and location of the USB connector under the cover.
The same applies to the Kospet Prime as well.
Hi to all, I’m Malex and logged now for the first time in the forum,and new happy owner of a kospet Prime.
First thing,greetings to all,thanks for your interesting forum,and sorry for my english.
I have a question.
After many days to explore all the forum and reset the watch for a stable bluetooth connection,now I have it,with watch droid 9.1,the same in the watch and phone,disable power saving and background cleaner,no battery optimization for watch droid.
but if I connect wifi,the connection is instable,disconnect and reconnect every 10-15 minutes,while should be more stable.
If I charge the watch connect to usb,with bluetooth and wifi connect,the connection is perfect,no disconnection for hours. this is because,when in charge,the power saver is disabe,but I have disabled too the power saving,so,when not in charge there is a sort of power saving in the wifi.
Is it a correct analysis?
I’m the only one?Have you a possible solution?
for me It’s a relative problem,because,only with bluetooth,the battery drain less than with wifi .
Thanks in advance
hello ,
I installed ‘‘Assistive Touch’’ for kospet prime, and i have a problem.
when I put the time dial, the application disappears.
Do you have a solution for him to stay permanently ?
tim_Collins , thanks you for the answer I have the pro version of this application, it closes as soon as I press the button of the watch I seek the solution so that it remains permanently ( I have been a subscriber for years @SmartWatch_Ticks ) :clin d’œil:
