lolā¦
I have alot of problems with this watch this is my first time owning one. I only worn it three times since I got it
Bands comes off by itself all I did was jog around a track. Notched something like a grove where the band inserted looks worn down. So how can I get it replaced so I actually wear this $200 watch I paid for
Earbud was horrible volume of music and calls always went in and out or just dropped.
Sims like thereās a double screen I donāt know if thatās a protector.
4 canāt wear the charging dock like in the videos yall say I could. Notice the only way the dock will work it had to be plugged in. Need to know how can I get it replaced
I am Australian.
It is 12.15am here and I am in bed.
I will message you tomorrow.
What is your time zone?
Well its 10:23 am here Iām in the USA eastern time
Please respond to my questions $200 is not to be giving away for a watch that is miss leading Iāve looking all the complaints and seeing all the basic feel good answers yall are giving people
@Kevin_Mack just so we understand each other ā
I am not in business with Jason.
We are an open community providing technical support for android watches - including the Genesis.
We do this for free.
We do not get paid at all.
We do not deal with hardware faults like broken straps or earbuds.
We are here for technical user support - like issues with firmware or software etcā¦
To help with your questions you should be posting in the correct support thread here The Genesis - from Kronos Blade
I will move your questions to this thread now because sending messages to one person means you have to wait for that person to be available. As you can see - my timezone is way different so the support thread is the place to be.
But I will try to answer your questions anyway.
Bands comes off by itself all I did was jog around a track. Notched something like a grove where the band inserted looks worn down. So how can I get it replaced so I actually wear this $200 watch I paid for - we cannot help with this as we are a technical support service - not hardware support.
Earbud was horrible volume of music and calls always went in and out or just dropped - about the calls dropping out - does this happen with and without the ear buds or just when using BT connection and ear buds? Have you connected the ear buds for hands free or music profile?
Sims like thereās a double screen I donāt know if thatās a protector - I suspect you may be seeing the screen protector or the reflective screen layer - please be EXTREMELY careful if you remove the screen protector and not scratch the screen.
4 canāt wear the charging dock like in the videos yall say I could. Notice the only way the dock will work it had to be plugged in. Need to know how can I get it replaced - the dock has to be fully charged and the small button on top of the dock has to be pressed to allow charging. This is to prevent two-way voltage draw. I cannot help you with āwearingā the charging dock. It is something that has to be worked out by watching videos and personal experience.
In my case, only the low brighness display is the problem. It still gives me more than a day of use. But just the same, pronlem is a problem. Jason already arrange for the return of the watch alone, so I can get a replacement. This is the good thing that we have a very supportive supplier to his customers.
The next Kronos should have 5x optical zoom capability with ois. Snapdragon 865 5g . 6 gb ram . 4k uhd display amoled . And should have atleast 4000mah battery .
Prior to owning the Kronos Genesis I owned a Zeblaze Thor 4 (charging pin fell out of the backing plate), 2 x Thor Proās (battery failed on one and Sim compartment rusted out on the other), 1 x Thor 4 Dual (non-removable band broke apart from the casing and cracks spread out from the charging pins in the plastic casing)⦠So far the Kronos Genesis is working fine for me apart from some inexplicable loss of phone network connection after rebooting. As far as these kinds of watches go this is the best one I have ever owned! Sure itās not perfect but for the amount of functionality inbuilt and the price paid compared to a Samsung Galaxy watch or apple watch which has far less features I see nothing to complain about.
I wonder why the case of the watch is the same as that of the Prime? Even though the battery is 30% smaller?
Itās the same as the Prime?
Hmm, ok.
Well anyway, this was designed and built in a completely different factory.
Itās case and build are very different to the Prime.
Jasonās idea was to have a slimmer watch - which means a smaller battery - but to be able to charge it when ever needed.
Thatās it⦠Thatās the reason.
Iām just going to leave this here.
This is a return video sent to Jason - asking for replacement or refund.
Apparently, the reason is āthe watch does not power onā
Anyway - make of this what you will ā¦
Hello again friends! I posted this in the firmware thread but wanted to see if anyone on this has any info on something Iām running into. I am trying to sync my work (outlook) calendar with Google calendars. I did some research and found that the way to do it is to make sure the outlook account is added in the āAccountsā section of settings as a Microsoft Exchange account. When I try to do that I am getting this message. I am not familiar with certificates and not entirely sure what this means. When i select āinstallā it takes me to my documents which is empty. Any ideas?
@pablo11 This is the most incredible video I saw. The watch looks as if it has been overrun by a car - several times! I would not have thought it possible for someone to abuse their watch and then request a refund. Incredible.
Deleted my first comment to the video, because I am more than speechlessā¦
What does YALL mean ?? is that hillbilly talk?
Kevin Mack., I can answer your question,
the watch rejects all owners of sub room temp intelligent quotient.,
BTW,. who is āāMiss Leadingāā? a Girl friend?
Agreed.
However, I wasnāt asking for a replacementā¦yet. Iāve been playing around with different apps that control the brightness, contrast, saturation, etc. to no avail.
As Pablo mentioned, this watch was really designed, more or less, for outdoor use. Of course, the sun does make a difference. However, indoor lighting is not as effective.
This is where this becomes an issue for me. Most of my time is spent in basements (more like dungeons) where servers and comm hubs are kept. I was hoping that the new FW addressed this issue and increased the max. I know itāll wash out the darker colors even moreā¦but using app dark modes should alleviate thisā¦IMHO
Uhhh. Why is that camera lens⦠Missing?
Sand. All. Over.
I wouldnāt dare
Believe it or not it is the result of removing protective plastic covers that werenāt there⦠
