Smarttouch watch face 2 versions
here is my first 2 watch faces. 2 versions both 21 touch points.
Smarttouch for those with the smart home
1/ google assistant
2/ ultra white screen flash light
3/ calculator
4/ Ring.com security camera
5/ MYQ garage door opener
6/ Amazon Music
7/ Phone dial pad (or if you install true dialer favorite contacts it will open that instead)
8/ stock camera
9/ facebook messenger
10/ chrome
11/ google photo’s
12/ amazon Alexa
13/ heart rate- opens heart rate app.
14/ step count - opens google fit
15/ battery indicator - opens battery usage details
16/hours- opens google clock ( not the stock clock app must install google clock)
17/ : -opens watch droid assisant
18/ minutes- opens settings
19/ seconds- opens screen brightness
20/ month -opens google calender
21/ weather indicator- opens current weather
lower battery indicator is only on if charging watch
bluehoneytouch21
1/ google assistant
3/ calculator
4/ Gmail
5/ Maps
6/ Spotify
8/ stock camera
9/ MMS messages
10/ chrome
11/ google photo’s
12/ Drive
https://drive.google.com/drive/u/1/folders/1L9AMVRWiJS6oYTkK3oiQ54T_R4R-aRaT
screen flash light and favorite contacts dial pad
Very nice - thanks mate.
Obviously a lot of work went into this !!
Good job! Thanks for sharing!
very nice.thank you
allcall gt does not load .please help
Thanks many hours into the first one. The 2nd was not so bad just editing a couple files in photoshop.
Are you using universal launcher?
I’m not sure why they wouldn’t be working I can look into yet they were working on my Genesis fine it may be that they don’t work on the stock launcher if you’re not using universal launcher
I like them!
No luck here loading to watch…comes across as “invalid File”. Prime 2, stock launcher
Are you unzipping to a folder (same name as the face) and then copy the folder to the Clockskin folder on the watch storage.
Then reboot.
Something isn’t working right on them. I’m guessing one of the files didn’t upload to drive correctly. The ones I pulled from my computer are working but these currently aren’t. Unfortunately I’m out of town for a couple days so will have to look at it this weekend when I get home. :man_facepalming:t3:
No worries, thanks
Hi, Very nice watch face, downloaded and unzip and uploaded the watch face bluehoneytouch21 folder to watch skin folder, but unfortunately it is not loading the watch face. please check. thanks
they should be working now, i was aware of the issue but out of town and not able to fix it till i got home.
Thanks for your hard work and sharing it with us.
I know it is not easy :+1::+1:
Much appreciated
its defiantly a lot of work, they can be fun tho once you get everything working correctly. still learning and figuring it all out. creating the files in photoshop is easy making sure you have the coding correctly. not so much
6 posts were merged into an existing topic: Hi All i have limited knowledge on wacthface creation so please be gentle! i
Cannot believe i missed this . Great work . I do love a touch zone or 20 :rofl::rofl:
Ok. See you.
Thanks for sharing well done
