DISCLAIMER: Use this at your own risk. This is provided as - is and it is your responsibility to understand and know how to use it.
- Download SP_Flash_Tool, extract it and launch flash_tool.exe
- Click on âchooseâ located next to âScatter-loading Fileâ and select âMT6765_Android_scatter.txtâ from the extracted archive:
- Click on âDownloadâ
- Turn your Smartwatch off.
- Connect your Smartwatch with the USB data cable.
It should start the flashing process now, donât interfere with the device until the process is done.
Thanks @none
Thank you so much.
the link is broken, can you make a new one, thx
I agree with tnchng, unfortunately the link ist broken. Would need the files to root my Lem 12 Pro. It does not work with the SP_Flash_Tool above from none. I have MT6762 (not MT6765). Would appreciate a new link, thanks!
It does not work any more since secure boot settings have changed and a secure signature has been used.
See if you can unlock the bootloader.
PS, they are all M6762 but show in some builds as M6765.
Too bad, but thanks for the information. Is there a tutorial for unlocking the bootloader? And then what are the next steps? Is root then possible? I am new here and would appreciate any tips. Thanks!
Itâs the same as any Android 10 device.
So easy to find on xda etcâŚ
However, I think the bootloader unlock is disabled on the recent firmware.
But you can read up about it and check.
The reason why we donât discuss this very often is the fact that root on Android 10 system as root is pretty useless and not worth the effort.
Any changes you make will upset the system verity and end up with a bootloop message âsystem has been tampered withâ.
This can only be fixed if you flash the firmware again.
Ok, then I will work without root. I would have liked to use some Tasker Task, but is not so important. More important and the real reason for asking for root would be for me an exactly working backup solution for Lem12 Pro, as I am used to from Titanium (with root) and also from Swift Bakup (with root). But that doesnât work then. But maybe there are alternatives for the smartwatch that work (almost) just as well? Would be grateful for a tip!
Hi this root file is deleted place help me and dawnload file
Have you read the posts up above yours?
yes i read it and i think itâs worth the effort
Yes, and I read your post and I have already explained that this file is no longer available because it will not work.
Itâs gone. Deleted.
