no not happening, the ticwris v1.7 flashes ok but the FAW still the same stuck at 95%
Have you used 7ZIP to unzip the FAW firmware?
yes but just incase something went wrong i will do it again
no still the same i compressed it and re unziped with 7zip and no joy still stuck on 95%…maybe im best downloading the FAW firmware again and trying again because every other firmware version you have given me has worked apart from the A10 FAW version…im back on ticwris max s v1.7 now
Hmm, I know it works. At the moment I have no idea what your problem could be.
Try leave it for a while and see if it keeps on flashing, it seems that it isnt connection problem if it gets stuck on the same % maybe it needs more time. BTW i didnt know that it is possible to flash A7 watches with A10.when youll succeed, plz tell what it gives you. I mean compare to what it was with A7.
just downloaded it again and tried again ,still stuck on 95% going leave it a bit see what happens
will do…but im not sure i will no as im going straight from 7.1 to 10 so i wont be using 7.1…,i never knew you could do this either untill i seen the thread on here about it with the ticwris max s…i let it sit on 95% for 35 mins unitll it came back with an error code 0xC005003 download exception
A10 is not available to flash on all A7 watches but it is available on this watch .
Where is the stock android 10 version,not the FAW 10 version, but the stock version that was never officially released,but released to you guys…i have seen the talk about it but cant find the download ? can i see if that works?i am now on the ticwris max s v1.9 that i found in the other thread…i have flashed about 4 diffent fimware version now and they all flash no problem in about 2 minutes,the only one that wont flash is the FAW-DM101- V1.OB firmware
As you say- the stock version is not available to you.
does it become available or not?
No, it won’t.
I have done it…i searched the error code and found this,see attached picture…i then deduced that it was a problem with my usb-c thunderbolt to usb connector so i then switched to another usb-c connector on my laptop and it worked…so it was my thunderbolt usb-c port that was causing the problem…giz a job…
Hello again, how do i switch from square to round screen on this version? can i even do that…as i notice the stock watch faces dont fill the screen,i know the touch on the faces doesnt work ive already read that, i also read about it has to be enabled in permissions manager but cant find the settings that were mentioned or im i confusing this with something else?ps thanks for all the help guys
I read in other posts that you flashed it successfully. I suspect that a bad USB port was the problem. If I’m right: It would be nice to report briefly in this thread that the problem is solved.
Press and hold the power button, then chose “scale” to change between round and square mode.
Yep, using USB C / Thunderbolt is not supported by the flash tool…
i have posted above what the problem was with usb thunderbolt and that i solved it…and when i press the power button the only options i have is restart,power off ,and recent tasks,there is no scale
Yep, because it is not needed.
If you need that, I suggest that you go back to the stock firmware.
I released this “as is”
It’s not to everyone’s taste.
pablo11Forum Manager
…… just to add,even though you mentioned its not supported by flashtool ,i managed to flash all other firmware with no problem ,ie Kopset note firmware,and version 1.3, 1.7, 1.9 of ticwris max s firmware using USB-C thunderbolt,its just the FAW A10 firmware wouldnt work untill i used my other standard USB-C port on my laptop…and just to make you aware on the FAW A10 version firmware when video calling on FB messenger that seems to have a problem as well with image being sideways like the lem 16 firmware was ,instead of being upside down like the lem16 was its sideways…but not to bother i dont use it very often…the FAW A10 firmware does seem to run better and the watch seems a lot faster.just a shame none of the stock watch faces with touch support dont work or fill the screen, while im here i mays well ask ,when answering a call i accept the call by pressing the phone icon but then i have to press the speaker icon to hear audio??? is that right because on other firmwares you only have to accept the call and it comes through the speaker automatically
