New Thor Pro
bicboi69
do you know how much battery consumer these apps are??? they keep the watch awake more even than google apps. i mean the battery usage app.
Sept 27, 2018 16:17:21 GMT 1 soniasophie9697 said:bicboi69
I only just installed it after i flashed v1.6 firmware. But so far battery seems decent now. After my last post, it only dropped to 75%. Idk if its just reading wrongly or not but I’ll wait n see how long it takes to drop to 30%. Once the battery life seems decent enough I’ll remove this accubattery app.
pablo11 AvatarSept 27, 2018 12:49:05 GMT 1 pablo11 said:leafar
He has the 1.6 version.
He flashed it today but is suffering from bad power consumption and artifacts on the screen at the 3 o’clock position.
Mine is root it and I don’t have those kind of issues and I get mostly like 10 hours a day with Bluetooth connection I don’t understand my so many peoples have problems, different batches, it’s like the always change something.
one more other thing he needs to calibrate all the sensors and the battery and let the battery run out, I did couples times in this watch and the LemX getting better results
Yea I have calibrated battery prior to flashing and battery was still draining like crazy. But it seems the battery life on v1.6 is incredibly better. Its been almost 6hours now and my battery is still at 44% and dropping consistently slow. I would assume it was the zeblaze firmware that couldn’t properly display my battery capacity. Now that im on a x300 firmware, all is good. Except BT connection seems to be kinda unstable. I tried installing watchdroid and it kept disconnecting so i removed it. Now my BT is turning off on its own more frequently lol
Try use Auto Bluetooth application if you Android smartphone maybe install in both devices, my Bluetooth connection it’s like 80% stable with my iPhone
pablo11 AvatarSept 27, 2018 11:04:50 GMT 1 pablo11 said:bicboi69 I am receiving it now from China. I can upload it overnight for you. It is a bit slow so as I am in Australia and it is already 8pm - it will be tomorrow.
Did u post the link in another thread? Lol so far my battery life aint amazing but it lasted from when i got to work til i get off work so that's something
I'll give it a try. I noticed if i turn on BT internet tethering, my watch starts turning off BT on it's own
bicboi69
Do you want to go back to the v1.5 firmware?
After reading your last few posts - it seems pointless going back to that version.
Maybe it would be better if you wait for the next version…
If you really want to go back to v1.5 I will start uploading now. Otherwise I will wait until the weekend.
pablo11 AvatarSept 28, 2018 12:38:34 GMT 1 pablo11 said:bicboi69 Do you want to go back to the v1.5 firmware? After reading your last few posts - it seems pointless going back to that version.
Oh wait, i thought u meant they're sending u a fixed v1.6 firmware?
bicboi69
They will. But it will be a while before it is ready.
The firmware I said they were sending is v1.5. Because you said the other version did not have the BT dialler - I said I would get it for you. So I did.
What I was suggesting was that if you are reasonably ok with the v1.6 firmware - it might be easier to wait for the next version?
pablo11 AvatarSept 28, 2018 13:03:45 GMT 1 pablo11 said:bicboi69 They will. But it will be a while before it is ready.
Ooooohhh! Yea i mean this version aint pretty but at least its reading the battery better. My watch still shuts down sometimes while charging and it really messes up my battery reading. It went from 60% and it turned off n became 88% instantly :/
Hi. How can i read full messages which i received? In notification, it only shown number of messages reveived.
use Watch Droid or M2D or Swapp Link instead of Wiiwatch.
Hi Sonia. Thks for ur help. I m using Watch Droid n it works on my Thor Pro. i hve deleted WiiWatch. TQ
Yeap watchdroid has been a godsend! A tip is just pay for it and u get the option of using ur watch local notification to view the texts. I had my watch set to silent so it doesnt vibrate twice for the same notification.
And for whatsapp i had it filter out notifications with ‘messages from chat’ that way u only get texts notifications n not the ‘3 messages from 2 chats’ thing.
Hey Pablo, I'd appreciate it if you could notify me here if you happen to get ur hands on the fixed v1.6 firmware in the future.
Oh and just wanna check if u encounter times when the battery reading is stuck for a long time? Lol mine was stuck on 95% while charging n that went on for 3hours then it got stuck on 99% after that for like 4 hours. Since its a Sunday, i wasn’t using it n ended up leaving it on charging for like 7hrs only then it was at 100%. I wonder if thats a good sign that the battery reading is finally calibrated :man_shrugging:
Uhhh so my watch turned off while charging again, this time it went from 13% to 89% instantly after it turned off. Shud i manually drain it first before charging or plug it back n the charger n hope it charges back up to a real 100%?
Oct 1, 2018 14:58:00 GMT 1 bicboi69 said:
plug it back let it reach 100% turn it on while plugged and make sure it is 100% or let it reach 100% when it is on.
btw, have you made sure the battery is well connected?
Yea I did that and it seems to be draining a little faster today but its not as bad as before so its okay for now.
Yeap thor pro comes with a snap on charging dock so its on there pretty tight, it should be well connected.
After all these few days of fiddling with it, i have to say im pretty happy with the setup now. So i kinda regret not rooting it first before downloading all these stuffs, could have save all these stuffs when the fixed v1.6 firmware is available i dont have to flash n redo all these settings again lol
