Because the lite version have a constraint I can only have one button, it is intended for"iphone users"which are generally people that are afraid of technology, having more then one button they will mess up
Feel free to use the source code for your perpouse, please make pr so I can merge this fix in before you customize to your own, and with the lite of both android and iOS, anyone can feel free to publish the app anywhere without my explicit permission
I am working now on making pr. if you managed to make some of these adjustments to the IOS version in the future I will be grateful
. Thank you.
With just one button really no more customization can be done, customizeability and ease of use doesn’t come together
had to hijack other peoples thread dfor rtosify because the rtosify thread got hijacked by others and had to be closed ![]()
No worries, I will try maybe i can find a solution.
Can you add a second branch in RTOSify Lite iOS gitlab because without a second branch, GitLab cannot show the “New merge request” button, because there’s nothing to merge from.
no need for new branch, after cloning my original code, made changes, you need to commit and push first, then you can make pull request to merge your main to my main
Ok I am trying since it is my first time ![]()
gitlab says there is 0 fork for rtosify lite ios btw which is not normal
What you mean, and what i should do?
i downloaded the project as zip file and then opened it with xcode
ask ai what to do now how to contribute
i did many steps as ai told me and it was not easy because i downloaded a zip project then i followed its instructions untill it told me to ask you to add me as a developer so i can continue.
there is no need to do it actually and o never used, still zero fork so not even moving in right direction
it is not correct to use download as zip you need to make a fork first then git clone
can we do as it says then you can remove me as a developer because i was wrorking for some time untill i reach this step and it is the last step.
No you completely gone in wrong direction
Not even close
how about give you the edited project as a zip file and you uploaded it then to gitlab?
It is not possible to upload the zip file to gitlab
If you do it I can still deal with it
I mean somehow like email or something else that accept zip files.
It is best you do it correct way but if not it is ok you can send me the file using wormhole.app
