I have added it to gitlab, can you check it? Is this correct what i did?
Nice work.
Glad you got into it ![]()
Thank you, I hope that I did the pr correctly.
you have created fork correctly now, but the changes is not commited and pushed yet, it still show your fork is up to date with the upstream
I sent you a message.
repository updated
i do question your code change, it is definately not the right way to do it, but i dont have devuce to test i cant really say anything
you removed device check at all so it would connect to any watch include other peoples that just so happen to be disconnected and put it into lite mode
Itβs working in my iPhone, but please go ahead and fix it in the correct way then I will test it, the app can work even better with your fixes.
without log i cant do anything
like this it will work if you dont have more then 1 watch near by
if someone want to provide a device for test i will do it correctly
