connect watch to phone by blutooth
Can somebody suggest MK settings or any settings to get good GPS location with 3G or Wifi and most of all ⦠with onboard-GPS.
Thankyou.
You should SP-Flash with updated ROM. I had this boot loop issue⦠and I didnāt unplug battery.
but I prepared sp-Flash with all necessary settings, and connect the device with USBā¦
⦠Since the SP-Flash was ready to download ROM, on the next boot-loop restart, it actually flashed the fresh OS.
it worked great after that.
Before i go running i firstly get a gps lock indoors with wifi , gps and sim . I open google maps , get a lock then go outside . Works well
that doesnāt work fine for me. I had to keep 4G on and battery drains like there is a big hole under my water bottle! ![]()
I always switch to 3g . Seems to keep the watch cooler etc . As for your battery drain it must be something else . I can do a 10k run with -
Wifi
3g
Screen always on
Bluetooth streaming music
Gps
Other apps closed and google sync off
From a fully battery and still have 30% left at the end ?
Its mean there is definitely something wrong with the watch! which firmware are you using? v0.9?
@all has anybody the scatter file for Lemfo LEM 10 1G/16G ?
Iād need it for some āadjustmentsā.
I found the rom; THX to @pablo11
If you are thinking of flashing this 3+32 version to a 1+16 version of the watch - just flash the system image alone and factory reset. Use download only mode in the flash tool.
Donāt bother with messing with the scatter file.
At your own risk !
Is this a 3/32 GB ? I think the twrp & root solution doesnāt work on a 1/16 ?
My Lemfo 10 after installing a timer application has stopped working, when you restart it, it makes the initial presentation of the brand and then it goes black, is there a set of buttons to perform a factory reset? Thanks in advance and sorry for English level.
Try press and hold the powerbutton for one minute. If this doesnt work, let the battery run dry. Then charge the watch completely. Now you should we able to turn it on again. Goto settings and delete this app.
If it doesnāt work, youāll have to flash the firmware.
Not sure itās dead but canāt yeat breath life into it and need suggestions.
It was on my wrist; had wifi and bluetooth on. Pretty sure it was a pretty full battery and had only been using for an hour or two when the bootup sound+animation played and screen went black
Holding down Power button is not bringing it to life; Iāve put it on to recharge - should there be any indication that is it recharging? If it did die due to no power, how long should it be charging before I can try and start it up?
I had a similar issue . I left to cool down and pressed and hold BOTH buttons for around twenty seconds and watch came back to life
. Let me know
@Dr_Andy_Vishnu hah, you are only teasing because both buttons are working for you xD
Oh yes
New LEM 10 FW update coming soon.
I will upload to the top post.
Great! And for some reason USB started working again so I can flash it! Yay.
Thatās a good thing
BTW dont upload the FW here; use the correct FW thread instead ![]()
